Toymods » Tech & Conversions » Intake Manifold- k series engine
benny
Intake Manifold- k series engine Mon, 22 August 2005 12:29 Go to next message
hi, i was wondering if there was an intake manifold on the corolla that didnt have that join to the exhaust manifold as i need to get an intake like this so it can be modified, if anyone could help or someone has one i could buy, it would really be appreciated. thanks
[Updated on: Mon, 22 August 2005 12:30]
Re: Intake Manifold- k series engine Mon, 22 August 2005 12:49 Go to previous messageGo to next message
nope.. well only the fuel injected 4KE and 7KE manifolds.. but they still have a bolt point for the exhaust.
the intake is a sealed unit and you can cut off the triangle at the base..
fwiw the early parallel runner manifolds have the triangle the opposite way round to the later ones..
are you trying to clear extractors? what is the purpose of getting one with no triangle?
gr8r-x
Vic, AU
Re: Intake Manifold- k series engine Tue, 23 August 2005 08:17 Go to previous messageGo to next message
I've got a single weber manifold that doesn't fit to the exhaust..
It does however have a (almost) heatsink like part below the placement for the carby, obviously to help atomise the fuel. Is this not suitable?
rollin_stock
February 2005
Re: Intake Manifold- k series engine Tue, 23 August 2005 08:23 Go to previous messageGo to next message
I found i had to fit the twin weber redline manifold to the headers i was using as the headers bolted up as standard but with the inlet manifold, redline decided that they would use all of the head studs... bastards
benny
Re: Intake Manifold- k series engine Tue, 23 August 2005 09:06 Go to previous messageGo to next message
its mostly cause it looks stupid, and with extractors it serves no purpose so i thought instead of getting an adapter plate i will get an intake modified.
Re: Intake Manifold- k series engine Tue, 23 August 2005 09:32 Go to previous messageGo to next message
well.. just cut and grind the bugger off...
although it does serve a purpose as a heat stove.. i would be tempted to leave the actual fin parts there to absorb some heat from the exahust.. i found fuel would often puddle in the bottom of my carb Sad
it was piss rich too but.... Razz
benny
Re: Intake Manifold- k series engine Tue, 23 August 2005 09:42 Go to previous message
what bout make a sheild inbetween intake and exhaust?
Previous Topic:Cars sharing same stud patten as ra65
Next Topic:Corolla KE 55 to Celica RA65 Brake & Strut conver Prob with Camber
Current Time: Mon Nov 2 15:01:40 UTC 2026
Total time taken to generate the page: 0.0046758651733398 seconds
