Toymods » Tech & Conversions » 18rg head on 22r block
4DaDrift
18rg head on 22r block Mon, 22 August 2005 15:45 Go to next message
is this possible and if so with what , if any mods to either the head and/or engine ?
edit:speeling
[Updated on: Mon, 22 August 2005 15:46]
Mr DOHC
Re: 18rg head on 22r block Mon, 22 August 2005 20:14 Go to previous messageGo to next message
wont work, just put the 22R crank and 16R rods in the 18RG block to stroke it
4DaDrift
Re: 18rg head on 22r block Tue, 23 August 2005 03:51 Go to previous messageGo to next message
are the long and short 22r cranks the same ?
16 or 18 rods ?
didnt know here was a 16r
woudl 18rg cranks be suffice of they have to be 18r ?
any idea what this woud stroke the engine out to ?
ive also heard theres different spec twincam heads
whats teh diff between them al and which suits what ?
[Updated on: Tue, 23 August 2005 03:52]
tricky
July 2005
Re: 18rg head on 22r block Tue, 23 August 2005 04:28 Go to previous messageGo to next message
Please don't stroke it!! It removes all revving characteristics of the engine, and basically you have a 22R with a flowing head. I know for sure that I prefer driving my 18RG RA23 to my Dad's 22R 'lux.
If u wanna larger capacity RG, you can bore it out to 2.2L (92mm I think) with no ill effects. The problem with this, however, is you need new, probably custom pistons ($$$). If you stroke it, it will be 2.4L, will have boatloads of low end torque, but it won't be revvy like an RG.
PS i dunno what your appplication is, and if it's in a hilux, the stroked option would be significantly better.
Keep us posted on your progress!
4DaDrift
Re: 18rg head on 22r block Tue, 23 August 2005 04:34 Go to previous messageGo to next message
actually for fathers corona wagon so require the torque yet also desire it to rev Smile
am i correct in assumign the reason it wont rev is due to the stroke beign significantly different to the bore and that this coudl be corrected by boring the engine as well as usingt he crank to stroke effectivelly creating something thats 2.6l + with twin cam in a 4 cylinder ?edit should also ask if the reving capabilites are due to the 22r crank beign significantly heavier ?
[Updated on: Tue, 23 August 2005 04:35]
Re: 18rg head on 22r block Tue, 23 August 2005 04:41 Go to previous messageGo to next message
Longer stroke means higher piston speeds. Shorter rods means higher side-loading on the pistons. Both are bad news for revs.
Solution: 18R-G with SC14 blower. Revs nicely AND has boatloads of torque. Smile
tricky
July 2005
Re: 18rg head on 22r block Tue, 23 August 2005 08:45 Go to previous messageGo to next message
yep, you def want torque, but a stroked RG will rev roughly the same as a 22r. Norbie's suggestion holds some serious meat, however! (such plans lead me to beleive it's an omen that my 18RG has a double row crank pulley Cool )
jeffro RA28
Tamworth
Re: 18rg head on 22r block Tue, 23 August 2005 09:44 Go to previous message
There different spec twin cam heads.
There is many different casting numbers
Castings numbers in order from best to worst, in my opinion
88270
88253
88250
these are the best 3 to use.
There are many more earlier versions. If u want to use stock cams use the cams from an 88210 or 88230.
All of them ca be used on the 18r block.
Previous Topic:100kw 4age redline
Next Topic:Cars sharing same stud patten as ra65
Current Time: Sun Nov 1 19:56:02 UTC 2026
Total time taken to generate the page: 0.0050938129425049 seconds
