Toymods » Tech & Conversions » how does a duel fuel controller work?
mkal6
melbourne
how does a duel fuel controller work? Mon, 22 August 2005 17:05 Go to next message
hi guys,
just got a duel fuel ea falcon and cant seem to figure out how the controller works and cant seem to find any symbols on it to make sense.
its a black box with green and red leds. there is a switch on it that once turned one way makes the 1 led turn red and nothing else where else when the switch is on the other way, the green leds light up and it looks like a gauge reading which shows the amount of gas in the tank.
will attach some pics if none of the above make sense
mo
M.J.H
Re: how does a duel fuel controller work? Mon, 22 August 2005 18:34 Go to previous messageGo to next message
If you want to run on petrol then have the red led light on and if you want gas then the green ones will light up instead.
Once its on gas then the gas comp cuts the fuel pump or fuel delivery to run on gas only.
Should get about 300klms from a 65l tank of gas around town.
mkal6
melbourne
Re: how does a duel fuel controller work? Tue, 23 August 2005 01:10 Go to previous messageGo to next message
cheers but there is another switch that changes is from gas or petrol. in other words, there is one switch that says petrol/gas and there is the black controller which also has a switch with the characteristics mentioned earlier
regards
mo
M.J.H
Re: how does a duel fuel controller work? Tue, 23 August 2005 04:21 Go to previous message
I,ve only ever seen one for the falcons.Maybe one switch died and was replaced with a second one i don't know.Are they both connected or not?
maybe some pics of these switchs would help.
Previous Topic:Help replacing SV21 drive shaft
Next Topic:Seat Rails for Bride seat.
Current Time: Thu Nov 19 14:58:42 UTC 2026
Total time taken to generate the page: 0.0064520835876465 seconds
