Toymods » Tech & Conversions » AE86 Front coil/damper units
Jimmy19650
Wodonga
May 2005
AE86 Front coil/damper units Mon, 22 August 2005 23:20 Go to next message
I am fitting MA61 struts, coil over conversion and RA60 control and steering arms to a Sprinter. I have read that by reducing the strut height by 40mm, it allows the use of an AE92/KP61 damper cartridge as used by TRD. Apparently, when lowering a sprinter, the operating range of the shock is altered causing problems at the extremities of the stroke.
The normal stroke range of a sprinter is 186mm, while the TRD conversions are 165mm. The TRD short stroke cartridges are 62mm shorter than a sprinter requiring a 22mm spacer in the bottom of the strut.
Does anybody have experience with this?
takai
Re: AE86 Front coil/damper units Tue, 23 August 2005 00:08 Go to previous message
Read the FAQ
http://forums.toymods.org.au/index.php?t=msg&t h=35782&rid=92&S=9cedaddd10e823383283f778b 39fa99c&pl_view=&start=0#msg_316747
Previous Topic:Organic vs Button clutch
Next Topic:91 soarer cruze controll probs
Current Time: Thu Nov 19 21:02:16 UTC 2026
Total time taken to generate the page: 0.0043439865112305 seconds
