Toymods » Tech & Conversions » Can any1 help with a soarer problem??
Lenso
Can any1 help with a soarer problem?? Mon, 23 December 2002 08:37 Go to next message
hi all,
I was wondering if anyone could shed some light on a problem
we're experiencing with a toyota soarer at work.
Here's the problem....
1.the owner hooked up the battery back to front and tried to jumpstart it.
2. once corrected, wound it over but it wouldn't fire.
3. its switching at the coils (getting power)
4. we have tested the crank-angle sensor at the computer side and getting correct responses from it.
5. sent the computer to be tested and it's ok.
6. signal to the injectors is weak
basically, it won't start and we have no information about these vehicles whatsoever.
if someone can help out it would be greatly appreciated.
THANKS
IRA11Y
Club Member
Re: Can any1 help with a soarer problem?? Mon, 23 December 2002 09:05 Go to previous messageGo to next message
Firstly youll get nowhere if you dont give an indication as to the model, year and engine of the vehicle.
Have you checked the ignitor? its probhably fried Very Happy
[Updated on: Mon, 23 December 2002 09:07]
SUPRAGTE
North Sydney
Re: Can any1 help with a soarer problem?? Wed, 25 December 2002 01:12 Go to previous messageGo to next message
Sounds like the amplifiers for the injectors in the ecu. But if you say it checks out fine its a bit strange. When they checked it did they load the injector outputs up or just check to see if they are triggering. They might not be able to handle a real physical load like the injectors.
How you checked the resistance of the injectors? What do they read?
BTW it wont be the ignitor if you say your coils are triggering. Dont waste time there, your on the right track with fuel. Very Happy
jase
Re: Can any1 help with a soarer problem?? Fri, 27 December 2002 06:53 Go to previous messageGo to next message
Dumb but....
Gone through all the breakers and fuses, I mean actually checked with a meter, not just look ok?, and checked the operation of the ciruit opening relay. It would stop fuel. (it may also stop other things your already saying work but)
I started a car once without the large ground connected to the engine, and the current went back to ground through a small part of the loom, and welded a relay closed.
Took me a week to find.
Lenso
Re: Can any1 help with a soarer problem?? Fri, 27 December 2002 10:18 Go to previous messageGo to next message
thanks everyone
when i get back to work after the xmas/new year break, i'll check out all your suggestions and get back to you
Thanks again.
Lenso
Lenso
Re: Can any1 help with a soarer problem?? Fri, 27 December 2002 10:21 Go to previous messageGo to next message
BTW, to IRA11Y
its a 1991/92 jzz30 soarer with the 1jz-gte engine.
Bounty
_Sydney _
Re: Can any1 help with a soarer problem?? Mon, 30 December 2002 11:15 Go to previous messageGo to next message
Good change ur fuel ecu is blown try this out....
Is it possible to by-pass a faulty fuel pump control circuit (ECU) in order to get home?
The fuel pump can be forced to operate in the high voltage setting by placing a jumper in the engine diagnostics connector between FP and +B terminals (for location of terminals see the label inside the diagnostics connector cover). A straightened up paper clip can be used as a jumper but must be inserted very deep in the terminals. This function is useful for checking that the fuel pump is not faulty (it can be heard running with the ignition on) and also to make the car mobile in case the fuel pump ECU is faulty. We strongly advise against driving the car for prolonged periods with the jumper inserted as the current draw of the pump in its high setting is about 7.3A and the pump may not have been designed to handle the load permanently and may overheat and seize, creating more (expensive) problems. At idle and under light loads the engine may be running rich due to increased fuel pressure.
Good luck.
SUPRAGTE
North Sydney
Re: Can any1 help with a soarer problem?? Wed, 01 January 2003 13:05 Go to previous messageGo to next message
Fuel pressure is set by the regulator isn't it bounty so matter what the pump is flowing the regulator sets the pressure anyway?
You shouldn't get richer af's at light loads?
Bounty
_Sydney _
Re: Can any1 help with a soarer problem?? Thu, 02 January 2003 06:26 Go to previous messageGo to next message
I just cut and pasted that from an article of FAQ's I dont know much abt the regulator so I cant really say.
Grant
Newcastle, NSW, Australia
Re: Can any1 help with a soarer problem?? Thu, 02 January 2003 10:28 Go to previous message
In all cases of 1J's being connected reverse polarity (that I have seen myself) the igniter is damaged and requires circuit board repair. You mentioned you were getting power at the coils but are you getting spark? If so, then the igniter has not been damaged.
If you do in fact have a damaged igniter we can offer a repair service. Please email me on sixworks@optusnet.com.au for further information or phone me on 0409 572904.
Grant Blundell
[Updated on: Thu, 02 January 2003 10:29]
Previous Topic:4A-GE into KE20
Next Topic:finding a LSD?
Current Time: Tue Oct 27 08:07:21 UTC 2026
Total time taken to generate the page: 0.023847818374634 seconds
