Toymods » Tech & Conversions » Boost controller setup, 3sgte
Jorrs
Coffs Harbour
Boost controller setup, 3sgte Tue, 23 August 2005 05:01 Go to next message
hey guys i am connecting a hybrid boost controller up to my 3sgte, st165 motor and have got it all wired up cept i need to connect wire to AFM and the wire in it which is map sensor wire i believe ? though i have a problem i dont no which wire is the map sensor wire in the AFM ? any help would be appareciated ? i have been to toyota and auto elecs no one has been able to help me out
Joshstix
Toymods Vice President
Re: Boost controller setup, 3sgte Tue, 23 August 2005 05:06 Go to previous messageGo to next message
An airflow meter and a MAP sensor are two different things that are used to achieve the same thing in a different way.
AFM cars measure the amount of air being ingested by the engine in order to calculate the fuel to inject. MAP sensed cars measure the manifold pressure and the air temp and use this to calculate the amount of air being used in order to determine fuel needs.
The AFM doesn't have a MAP sensor in it, at least no AFM I know of does. In the Gen 2 #sGTE's however they did run a map sensor to run the boost guage and operate the boost cut. This is mounted close to the intake manifold on the drivers side, at least it is in a Gen 2 SW20.
I don't know if the Gen 1 has a Map sendor or not, but based on the way Toyota generally do things I'd expect there to be one there somewhere.
Sorry I'm not much use to you, get your hands on a wiring diagram for the generation of engine you're using and it shouldn't be too difficult.
Jorrs
Coffs Harbour
Re: Boost controller setup, 3sgte Tue, 23 August 2005 05:10 Go to previous messageGo to next message
mmmmmmm i have been unable to get wiring diagram so far for it, though i did find an ECU pinout diagram can i run it straight through the ECU ?
MR. 2
Parramatta
Re: Boost controller setup, 3sgte Tue, 23 August 2005 05:40 Go to previous message
the ecu pin out probably wont be all that much of help to you, i would say you need the wiring diagram. for a 162 i have no idea.
sorry
Previous Topic:Turbocharging 4AGE .
Next Topic:Help replacing SV21 drive shaft
Current Time: Thu Nov 19 14:40:28 UTC 2026
Total time taken to generate the page: 0.030841827392578 seconds
