Toymods » Tech & Conversions » FWD Hub Nuts
strutto
Gold Coast
FWD Hub Nuts Tue, 04 June 2002 15:47 Go to next message
Can anyone offer any advice as to why my drivers side hub nut keeps coming loose. It's done it twice now.
Do I just need to torque it up some more or is something rooted?
Would Loctite help?
AE92 100kw engine, box, drive shafts and hubs.
Thanks,
jasonp1977
Re: FWD Hub Nuts Tue, 04 June 2002 20:48 Go to previous messageGo to next message
have you got the cap and cotter-pin inserted? I cant really see how it could be coming loose if you do... how tight are you torquing the nut?
strutto
Gold Coast
Re: FWD Hub Nuts Wed, 05 June 2002 00:53 Go to previous messageGo to next message
Cap and split pin are installed. Don't reckon I'd have a drivers side wheel (or car more than likely) if I hadn't put em on. The nut is coming loose inside the cap if that makes any sense.
Torque? Big ratchet, big socket, big breaker bar. Kept tightening until I thought it was tight enough. Sad
haggis
Re: FWD Hub Nuts Wed, 05 June 2002 02:28 Go to previous messageGo to next message
You should really be tightening to the correct torque. I have it listed at home if you need it, but any Corolla service manual should have it.
Check the threads of the stub axle (CV joint) and see if they are worn or streached.
Invest in a torque wrench. best $90 you can spend if you do a lot of work on your own car!
Craig.
Re: FWD Hub Nuts Wed, 05 June 2002 08:06 Go to previous messageGo to next message
If you have the "correct" nut retainer and split pin on, there is no way the nut will come loose!
Xauterus
Re: FWD Hub Nuts Wed, 05 June 2002 12:48 Go to previous messageGo to next message
Hi
I would seriously strip that hub down and see whats causing the problem. I have seen the drive flange getting chewed up where it contacts the bearing inner race or the bearing its self getting worn. If the nut is locked its not magically coming loose, there has to be something wearing inside to be causing it to come loose. Do it sooner rather than later.Best of luck
Corey
strutto
Gold Coast
Re: FWD Hub Nuts Wed, 05 June 2002 13:20 Go to previous messageGo to next message
Haggis: I'll borrow a torque wrench tomorrow. I have the torque settings here somewhere... The thread on the stub axle looks fine... as do the splines.
Cool1: I assume Toyota fit the "correct" nut retainer and split pin from the factory? I can assure you, it's coming loose...
Xauterus: I've had a good look at the hub and bearing and nothing seems worn. I took it off the road as soon as it happened. It's probably had about 30 mins worth of easy driving with it loose.
I pretty sure I just didn't torque it up enough now. I'll torque it properly tomorrow and let you all know how it goes in a few days.
Many thanks to all of you for the advice... Don't know where I'd be without Toymods...
P.S. Loctite? Good? Bad? Useless? What sort?
Re: FWD Hub Nuts Wed, 05 June 2002 13:29 Go to previous messageGo to next message
I really cant understand how the nut can come loose without spreading the fins on the retainer! Even if you only did the nut finger tite, the retainer should stop the nut from spinning!
Make sure the fins are pressed against the flat edges of the nut!
strutto
Gold Coast
Re: FWD Hub Nuts Wed, 05 June 2002 13:43 Go to previous messageGo to next message
Cool1 wrote on Wed, 05 June 2002 11:29 PM
I'll double check the retainer as thats a really good point. Bear in mind it's only coming loose about 1/8 of a turn or less. There seems to be a small amount of slack in the retainer when installed? What do Toyota want for new retainers?
Thanks for the advice...
Re: FWD Hub Nuts Wed, 05 June 2002 20:51 Go to previous message
I dont think a retainer would cost very much. You could just get a second hand one from the wreckers!
Previous Topic:t-vis na cams into ze?
Next Topic:Solex sidedraft jets?
Current Time: Thu Nov 19 21:08:06 UTC 2026
Total time taken to generate the page: 0.022259950637817 seconds
