Toymods » Tech & Conversions » hard shifting when engine reaches normal operating temps...
chadix24_7
cebu city, philippines
hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 08:41 Go to next message
when cold, it shifts fine like a brand new car would shift, but as the engine heats up to normal operating temperature, hard shifting occurs. just replaced the tranny fluid with a new one, clutch lining, pressure plate and release bearing are 6 months old, just used the car on sundays wherein the streets aren't busy....,... but still the problem persisted.
this problem occurs on a full stop especially on traffic days.
it would change gears fine if the car is moving.
engine is a 7age in an ae101 sedan.
Spanktown
Inside a giant turbo (syd...
Re: hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 08:43 Go to previous messageGo to next message
sounds like the gearbox oil is too thin, ie when its hot, it gets too thin and isnt working properly.
SW20R
Re: hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 08:44 Go to previous messageGo to next message
maybe wrong fluid?
[Updated on: Tue, 23 August 2005 08:46]
inertia
Re: hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 08:54 Go to previous messageGo to next message
Clutch fluid/clutch line heating up too much causing it to be hard to disengage?
chadix24_7
Re: hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 08:57 Go to previous messageGo to next message
i used the SAE 90 API GL4 (as what it is written on the bottle)...
is that too thin? what is your recommendation? Smile
allencr
tallahassee FL usOFa
Re: hard shifting when engine reaches normal operating temps... Tue, 23 August 2005 15:10 Go to previous message
first, figure outif this is a clutch or transmission problem.
clutch dragging.
how's reverse - cold & warm?
that'll tell you if it's dis-engaging OK.
if it's OK, then it's the trans, but i really doubt it, and different oil wouldn't help in any case.
different gear oil does help, sometimes, in the opposite condition of difficult shifting when cold but fine when warm.
Previous Topic:Where to buy 4A-G 20v billet cams
Next Topic:Someone to do 20v 4age conversion for AE95 (melb)
Current Time: Fri Oct 30 19:52:12 UTC 2026
Total time taken to generate the page: 0.0055420398712158 seconds
