Toymods » Tech & Conversions » master/booster upgrade to suit GT-R brakes
rokusan
western queensland
master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:33 Go to next message
Does any one have any ideas about what to use to upgrade the master and booster on my SA63 for gtr nissan brakes front and rear?
Is there a supra or hilux of some description that has large capacity brakes that i could fit the master and or booster from??
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:35 Go to previous messageGo to next message
Are these 296mm GTR brakes? or 324mm GTR brakes?
Measure the piston size.
For 296mm brakes the stock m/c is fine.
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:38 Go to previous messageGo to next message
do you mean discs? they are R33 gtst front and 32gtr stock rears
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:41 Go to previous messageGo to next message
Well, sort of.
The series 1 R32 GTR uses 296mm discs and Sumitomo calipers, where as Series 2 R32 GTR and on use 324mm discs and Brembo calipers.
I know from comparing the MA61 brakes to Skyline 4 spots/2spots (non Brembos) that there is negligible difference in piston area, so a change in master cylinder is not required.
However, you had drum rears, so I'd suggest you get an MA61 master cylinder and call it a day.
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:46 Go to previous messageGo to next message
Cool, yes they are just the cheap sumitomo's, so what about the booster?
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:47 Go to previous messageGo to next message
I doubt there is a different between the MA61 booster and the SA63 booster, but just for keeping it simple, use the MA61 booster too.
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 09:58 Go to previous messageGo to next message
San-chu haiiri krutch Very Happy i will now be off on a search for an MA61 master etc.
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 13:33 Go to previous messageGo to next message
MX83 1 inch cylinder
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 13:41 Go to previous messageGo to next message
Skyline pistons have less surface area than MA61 pistons, so no need to upgrade m/c
XmaGe
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 13:45 Go to previous messageGo to next message
Supra A70 brake booster... might have to bend your pipes to fit but it'll be strong enough.
Re: master/booster upgrade to suit GT-R brakes Tue, 23 August 2005 15:40 Go to previous messageGo to next message
I've played with a couple of sets of Nissan calipers, and find they feel soggy with less than a 1 inch cylinder, but it's a matter of what you like I suppose.
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Wed, 24 August 2005 11:15 Go to previous messageGo to next message
i will need goodly brakes, my car won't be road rego'd.
will the MX83 mc fit up to the SA63 booster thats the next Q?
off to toyota at lunch for some research Smile
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Fri, 26 August 2005 07:55 Go to previous messageGo to next message
well after a wee play on the toyota parts files and a flick through a PBR catalouge i've come up with this.
MA61, SA63 etc have 23.81mm piston, same master cyl. and MX83 has ABS and diff. MC.
also Z32 nissans have 23.81mm piston too.
and i've finally found the resrtictor for the drum in the very front of the master.
Hopefully if i drill this out i'll be fine for brakes, well hopefully
Re: master/booster upgrade to suit GT-R brakes Fri, 26 August 2005 08:02 Go to previous messageGo to next message
Z32 Nissan should have a 1 1/16" master? At least the later ones should.
Stock is 15/16" yes, MA70 is 1"
EDIT: Z32 TT m/c are 1 1/16", or 26.98mm
And MX83 is 1" too.
[Updated on: Fri, 26 August 2005 08:06]
Re: master/booster upgrade to suit GT-R brakes Fri, 26 August 2005 12:41 Go to previous messageGo to next message
uzs131 is 1" too Smile
funnyly enough - the ST205 brake MC is 15/16", but the brakes themselves are MASSIVE!!! Waaay bigger than any of the other toyotas listed above.
i think there is more to it than just bore diameter...
Re: master/booster upgrade to suit GT-R brakes Fri, 26 August 2005 13:20 Go to previous messageGo to next message
pedal ratio perhaps?
takai
Re: master/booster upgrade to suit GT-R brakes Fri, 26 August 2005 14:39 Go to previous messageGo to next message
For reference, i use Hilux calipers on the Sprinter, along with a Mitsubishi Starion (15/16") master and the pedal feel is quite nice. Im switching to the Nissan brakes, simply for weight, but from driving a very similar setup car (15/16" and GTST brakes) the 15/16th seems pretty good.
Thinking of swapping in a R32 1" master to go along with it though.
rokusan
western queensland
Re: master/booster upgrade to suit GT-R brakes Sat, 27 August 2005 05:02 Go to previous messageGo to next message
CrUZsida wrote on Fri, 26 August 2005 18:02
And MX83 is 1" too.
???? was i looking at a different catalouge????
Re: master/booster upgrade to suit GT-R brakes Sat, 27 August 2005 06:22 Go to previous message
Get the ATAP catalogue.
If its not on the site anymore, PM me you email addy and I'll email it over.
Previous Topic:refitting TA22 rear window
Next Topic:1mz-fe from camry or avalon in lexus rx330?
Current Time: Wed Oct 28 00:40:23 UTC 2026
Total time taken to generate the page: 0.0049159526824951 seconds
