Toymods » Tech & Conversions » Welding / Bogging holes in engine bay
NAJJE
Welding / Bogging holes in engine bay Tue, 23 August 2005 09:58 Go to next message
All,
I am in the process of installing a 3T-GTE in my TA22.. I am stripping the engine bay back and have re routed the wiring loom through the gaurd and trying to neaten up the engine bay as much as possible.
My questions is...
I have only got an ARC welder and trying to weld up the holes that are no longer being used. (ITS A BITCH)
Do people weld these shut, or bog these in?
I am a bit worried that Bog will crack over time and my welder isn't the best for such thin material. Need TIG or MIG I think.
Any sugesstions would be great!
Rob
rollin_stock
February 2005
Re: Welding / Bogging holes in engine bay Tue, 23 August 2005 10:06 Go to previous messageGo to next message
yeah ya need a mig, not tig (aluminium). if you want it to last dont bog em...
gearb0x
Re: Welding / Bogging holes in engine bay Tue, 23 August 2005 10:53 Go to previous messageGo to next message
u could allways use reallly really big rivets for that JDM drift look Laughing
Mig welder is the way to go, just spot it on dont hold it on too long and u should fill the holes, or cut a little bit of sheet up for the bigger start, then spot around hole at oposite ends, almost like doing a head up Smile
Re: Welding / Bogging holes in engine bay Tue, 23 August 2005 13:29 Go to previous messageGo to next message
You can use a TIG, just a lot more work. Oxy or MIG are the go.
feral4mr2
Bundaberg, Qld.
Re: Welding / Bogging holes in engine bay Tue, 23 August 2005 13:33 Go to previous messageGo to next message
i can vouch for arc welders blowing holes in panels. i've just come up from the shed after welding a cracked inner guard and fender on my 4wd.
all i have is an old arc welder, the cracks/splits are fixed now, but the panels do have a couple complimentary breather holes now... Laughing
o_man_ra23
Townsville North Qld
icon10.gif  Re: Welding / Bogging holes in engine bay Tue, 23 August 2005 23:50 Go to previous messageGo to next message
mig the bugger.
also, can you email me details on how you performed this conversion, as i will be doing the same to my mate's TA22 in a couple of weeks once we finish welding the body on his missus' rolla. were there any niggly bits that cropped up?? or was it really simple??
HyDrA
Adelaide, SA
Re: Welding / Bogging holes in engine bay Wed, 24 August 2005 01:44 Go to previous messageGo to next message
Panels may not survive Arc, but I know the thicker chassis metal can make it.
I want a mig Sad
clubagreenie
1st street on the right
Re: Welding / Bogging holes in engine bay Wed, 24 August 2005 03:41 Go to previous messageGo to next message
Why not fill with gromets???
rokusan
western queensland
Re: Welding / Bogging holes in engine bay Wed, 24 August 2005 10:20 Go to previous messageGo to next message
i have had good success with fibreglass behind the small holes then bog and tacking a patch behind the larger ones then filling it with bog, just use a good quality bog it will last as long as needed
NAJJE
Re: Welding / Bogging holes in engine bay Wed, 24 August 2005 12:21 Go to previous messageGo to next message
Cheers for the replies...
Fibre glass sounds like a good idea, but I might pinch my mates MIG welder to do the job!
Ill post some pics once its done... Still stripping paint Razz
Never realised how usefall My new Air Die grinder is with flap wheels to smooth burs off and take back to metal... Best tool I Ive bought!!!
Thanks for the replies
Regards
Rob
jcmunga
adelaide
Re: Welding / Bogging holes in engine bay Sat, 27 August 2005 00:20 Go to previous message
if you do use a mig, use no bigger than .7mm wire on low voltage and keep the wire moving at a good speed, this stops it getting too hot.
if you use thicker wire you need higher volts and heat created by the thicker wires will blow holes
jesse
Previous Topic:Quad throttle throat sizing questions
Next Topic:AE101 4agze ---> SX selector problem
Current Time: Wed Oct 28 00:40:30 UTC 2026
Total time taken to generate the page: 0.012399911880493 seconds
