Toymods » Tech & Conversions » No TPS on 4AGE
rollaboy
Coffs
icon5.gif  No TPS on 4AGE Mon, 23 December 2002 11:57 Go to next message
Whats the go with this..Theres a AE82 seca twincam with the big port 4age at my mum's mechanics and he said its not running the TPS..how would it work out the mixtures etc??
Would it have a After market ECU or something??
spr000
Re: No TPS on 4AGE Mon, 23 December 2002 13:36 Go to previous messageGo to next message
I thought 4age was either MAP or MAS sensored? Usually the TPS is for aftermarket system, or it's to sense the throttle position to turn the air cond off..
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: No TPS on 4AGE Mon, 23 December 2002 14:13 Go to previous messageGo to next message
Nah the 4A-GE actually runs a proper variable resistor type TPs, rather than a simple switch type. It uses this in conjustion with the MAP sensor.
I can't see how it could run without any type of TPS, have a look at it if you can, check out the ECU, the throttle body & the wiring.
See if anything else has been changed. Find out how it runs too.
Pumpkin
Re: No TPS on 4AGE Tue, 24 December 2002 01:23 Go to previous messageGo to next message
I don't know about the 4AGE's but the 2TGEU runs fine without it's TPS... Confused
TE72_Turbo
Re: No TPS on 4AGE Tue, 24 December 2002 07:18 Go to previous message
I believe the TPS on the 2TG is basically used only as a throttle switch, showing throttle closed, flat out, or somewhere inbetween, but not variable between either extremity, so it probably doesnt serve as important a role.
TPS is generally used for functions such as closed loop, and fuel cut on deceleration, so your car 'should' still run fairly well without it connected, unless the ECU has a "limp home" mode where it runs a very basic map when it recognises that a sensor is not there or disconnected, in which case it wont perform too well.
Hope that makes sense Confused
CHeers
Phil
Previous Topic:wiring diagram - 4age redtop
Next Topic:18RG Turbo Cooling System Problems
Current Time: Thu Oct 22 03:06:51 UTC 2026
Total time taken to generate the page: 0.005134105682373 seconds
