Toymods » General Car Talk » What gear should a dyno be run in?
ndgcpr
Pine Rivers QLD
April 2005
What gear should a dyno be run in? Tue, 23 August 2005 11:14 Go to next message
well thats about it does it matter what gear a dyno is run in? and do different gears give different results
Spanktown
Inside a giant turbo (syd...
Re: What gear should a dyno be run in? Tue, 23 August 2005 11:49 Go to previous messageGo to next message
you want to run it in the gear that gives you 1:1 ratio, or closest too... usually 4th gear in a manual car.
Re: What gear should a dyno be run in? Tue, 23 August 2005 11:56 Go to previous messageGo to next message
Baaaaaaaaarp, incorrect
You need to run it so that the dyno is at its most accurate.
For instance, dyno dynamic dyno's are most accurate with the rollers spinning from 100-140kph.
So most manuals are done in 3rd.
In theory you should get an almost identical reading when done in 4th though.
Corona RT142
Campbelltown
Re: What gear should a dyno be run in? Tue, 23 August 2005 22:56 Go to previous messageGo to next message
at the toymods dyno day at SAS pretty much all manual cars were run in 4th gear, but with the new software it shouldn't matter anyway. This topic was discussed in detail after the dyno day in a thread started by RAV GT4, in the tech section.
Want more info search and find it. Very Happy
TT_50AR
sydney, turramurra
April 2005
Re: What gear should a dyno be run in? Wed, 24 August 2005 05:11 Go to previous messageGo to next message
autos r done in 2nd
ndgcpr
Pine Rivers QLD
April 2005
Re: What gear should a dyno be run in? Wed, 24 August 2005 07:01 Go to previous messageGo to next message
Corona RT142 wrote on Wed, 24 August 2005 08:56
nope that all the info i wanted. i have been told both ways and wanted clarification. and what do you search??? i tried but only got people say "how good was it on the dyno"
Corona RT142
Campbelltown
Re: What gear should a dyno be run in? Wed, 24 August 2005 07:03 Go to previous message
http://forums.toymods.org.au/index.php?t=msg&g oto=695206&rid=4118&S=c1295cbaad686decd239 c12567f6bab7
done
Previous Topic:Daily Driver Recommendation
Next Topic:gf or car
Current Time: Tue Oct 27 11:18:58 UTC 2026
Total time taken to generate the page: 0.011919975280762 seconds
