Toymods » Tech & Conversions » Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup?
NoShoes
Georgia, USA
Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Mon, 23 December 2002 17:07 Go to next message
I thought I'd ask you folks if anyone down under has performaed the swap. My major concern is where (in the world) can I find a bellhousing for the stock pickup tranny that will mate to the 3S block.
Any other details, or an e-mail addy of someone who has done a swap like this would be appreciated.
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Tue, 24 December 2002 00:41 Go to previous messageGo to next message
What box is in the pickup?
NoShoes
Georgia, USA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Tue, 24 December 2002 01:49 Go to previous messageGo to next message
Oops, I expect that would help.
The truck is a 90 2wd model with the 22R motor in it. The transmission is the factory 5 speed.
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Tue, 24 December 2002 02:49 Go to previous messageGo to next message
I would expectn it to be a W5* box? In this case the 1S or 2S bellhousing will bolt up!
The problem with the 1S/2S housing is that it puts the starter under the turbo! There is a place in N/Z that sells these bellhousings modified with the starter on the drivers side! They cost about $200NZ!
But first you really need to figure out what box you have!
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Tue, 24 December 2002 06:52 Go to previous messageGo to next message
I'd say your box is a W5x...
Do a search for "RWD 3S" or something simiilar. This topc has been covered many, many times over...
It's not an easy swap...
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Tue, 24 December 2002 14:58 Go to previous messageGo to next message
Could also be a G52 or an L50. Check the ID plate in the engine bay to be sure.
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 11:44 Go to previous messageGo to next message
I have a 1990 4wd toyota hilux (pickup) it has a g52 box.
Today is the first time on this forum and it's freaky, I came on to find out about doing a 3s gte swap into a hilux (though mine's a four wheel drive) I'll be very interested in this thread!
I have found that the 82 supra gearbox bellhousing will bolt straight to the hilux(pickup) g52 gearbox and therefore the 3sgte will fit up. Everything else will go with some amount of work.
This guy has put an inline six Toyota motor, not quite what you are after but the bellhousing info will be useful.
http://www.4x4wire.com/toyota/tech/supra/
[Updated on: Sat, 28 December 2002 11:58]
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 12:34 Go to previous messageGo to next message
But the supra bellhousing wont bolt up to the 3S-GTE!
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 12:56 Go to previous messageGo to next message
I read somewhere that a w58 or a 2s housing will fit between the 3sgte and the hilux box, please correct me if im wrong,
Thanks mate!
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:03 Go to previous messageGo to next message
The 1S/2S bellhousing will bolt onto a W58 box which will then bolt to the 3S-GTE!
But remember that the bellhousing needs shortening!
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:19 Go to previous messageGo to next message
So.....3sgte to 1s/2s housing to w58/g52 box, I'm sure I read somewhere on these forums that a w58 will bolt up to 3sgte, I think I have been on the net too long, my head hurts! Razz
Jayem
Finland
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:24 Go to previous messageGo to next message
1C bellhouse should sit to S-series motor and to W-series box.
Try to find info...
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:26 Go to previous messageGo to next message
gibbo wrote on Sat, 28 December 2002 23:19
Yes this is correct!
A W58 box will bolt up to a 3S-GTE using a 1S/2S bellhousing Very Happy
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:33 Go to previous messageGo to next message
you know what I meant Embarassed
[Updated on: Sat, 28 December 2002 13:35]
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 13:39 Go to previous messageGo to next message
When you say the bellhousing needs shortening, where is that done, eg front face, cut and shut, rear face?
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 14:09 Go to previous messageGo to next message
It just needs a bit machined off! Both ends would be the best in my opinion to keep the strength! I think about 15mm needs to be taken off!
NoShoes
Georgia, USA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sat, 28 December 2002 16:41 Go to previous messageGo to next message
From what I understand, the 2S bellhousing locates the starter right where the turbo assembly sits. That's not a good thing! Someone told me that a company in New Zealand makes a bellhousing that relocates the starter to the intake manifold side. Does anyone know of this company?
Also, I am not familiar with the 2S. What vehicles did it come in? I'm going to need motor mounts, flywheel, and a few other odds and ends from a 2S equipped car, but I have no idea where to source them, since I'm a US fellow. I DO have the capability to import stuff from Japan, or Australia. Anyone have any ideas?
gibbo
Adelaide SA
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sun, 29 December 2002 02:21 Go to previous messageGo to next message
From what I have read in these forums, the company is http://www.fraser.co.nz, I couldn't find anything about the bellhousings, might be worth a call or email.
Did you find out which box you have?
Re: Has anyone ever swapped a 3S-GTE into a 89-93 Toyota pickup? Sun, 29 December 2002 02:32 Go to previous message
Fraser is the right company to get the bellhousing from! They take the 1S/2S housing and shorten it and also relocate the starter to the inlet side!
Give them a call and speak to Neil!
Previous Topic:4age throttle bodies
Next Topic:Door Closing Problem
Current Time: Thu Nov 19 17:40:14 UTC 2026
Total time taken to generate the page: 0.0074849128723145 seconds
