Toymods » Tech & Conversions » 4AGE 100kw Cams
GTI16V
CROMER, NSW
4AGE 100kw Cams Tue, 23 August 2005 23:31 Go to next message
Has anyone put a set of cams in a 100kw 4age if so what cams and what results have you got.
shinybluesteel
melbourne
Re: 4AGE 100kw Cams Tue, 23 August 2005 23:48 Go to previous messageGo to next message
sorry, re-read your post and it didnt deserve my response.
a small upgrade is to fit bigport cams, as they are slightly higher lift and longer duration, but with the stuffing around involved, might as well go aftermarket.
[Updated on: Wed, 24 August 2005 02:53]
Hodgo
Re: 4AGE 100kw Cams Wed, 24 August 2005 00:10 Go to previous messageGo to next message
PWNED?
Re: 4AGE 100kw Cams Wed, 24 August 2005 00:13 Go to previous messageGo to next message
shinybluesteel wrote on Wed, 24 August 2005 07:48
mine came with cams, so i didnt have to put any in.
i'd imagine the results you would get are a running engine.
Can we just have someone please answer questions sensibly for once? Rolling Eyes
SW20R
Re: 4AGE 100kw Cams Wed, 24 August 2005 00:39 Go to previous messageGo to next message
i think he means aftermarket cams?
on a 4AG depending on what lift and duration they can give you 2-10kw more
GTI16V
CROMER, NSW
Re: 4AGE 100kw Cams Wed, 24 August 2005 01:02 Go to previous messageGo to next message
Yes i do mean aftermarket cams.
ae86trueno
Re: 4AGE 100kw Cams Wed, 24 August 2005 01:55 Go to previous messageGo to next message
I have had both 304 Deg 7.5mm and 280 9mm cams in my 100KW
304's were good at the track with lots of grunt high up but lacking down low torque needed on the dirt,
the 280's have tons of push you back in the seat torque from 4000 onwards.
But having said that with the close ratio gearbox and the 5.1 diff its not really streatable.
oh and you need quads and computer if you go above 260 Deg.
Ben.
ehendrikd
ballarat
Re: 4AGE 100kw Cams Wed, 24 August 2005 03:38 Go to previous messageGo to next message
ae86trueno wrote on Wed, 24 August 2005 11:55
please excuse my ignorance, but i can understanding needing a programmable computer, why are the quad throttle bodies needed?
Karl_skewes
New Zealand
Re: 4AGE 100kw Cams Wed, 24 August 2005 03:57 Go to previous messageGo to next message
Ben, got any dyno graphs?
ae86trueno
Re: 4AGE 100kw Cams Wed, 24 August 2005 04:42 Go to previous messageGo to next message
Quads arent needed but I would recommend them as once you get to about 272 you start to loose the benefit of having larger cams and if your going to go this far an extra couple of dollars will give you a big performance improvement.
Here is an poorly scanned old graph
http://members.optusnet.com.au/sun_moon_stars/Image24.jpg
Ben.
ehendrikd
ballarat
Re: 4AGE 100kw Cams Wed, 24 August 2005 04:44 Go to previous messageGo to next message
cool, the quads arn't strictly needed, but highly recommended Smile
takai
Re: 4AGE 100kw Cams Wed, 24 August 2005 05:57 Go to previous messageGo to next message
Ben: which cams were those?
I dont have my dyno graphs on me atm, but i run 308*s in my smallport, with 20v quads. Pulls around 130rwhp.
koen
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:00 Go to previous messageGo to next message
What's that like around town, takai? Stock compression? And what ECU are you using?
Thanks Smile
takai
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:06 Go to previous messageGo to next message
Its horrible, i dont drive it around town though, it is my race car after all. I would probably be shot, crucified, and then hung drawn and quartered, and then shot again for good measure if i drove it around town.
Still a stock bottom end, because im trying to get the suspension right before i rebuild the engine.
Corona RT142
Campbelltown
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:07 Go to previous messageGo to next message
There was a white sprinter at the last toymods dyno day that put 122rwkw out of a NA 4age, i think it was a small port.
koen
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:16 Go to previous messageGo to next message
takai wrote on Wed, 24 August 2005 16:06
Hahahahaha, righto Smile
ECU? Or is it a secret?
takai
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:26 Go to previous messageGo to next message
Haltech E6x
GTI16V
CROMER, NSW
Re: 4AGE 100kw Cams Wed, 24 August 2005 06:47 Go to previous messageGo to next message
Am thinking about buying some wade cams about 262degree duration and about .33 inch lift.According to wade cams these will run on the stock ecu no problem at all.
[Updated on: Wed, 24 August 2005 06:48]
BradW
Bottom of the hill, Sydney
Re: 4AGE 100kw Cams Wed, 24 August 2005 07:15 Go to previous messageGo to next message
GTI16V wrote on Wed, 24 August 2005 16:47
Have you priced these yet?
I'd be interested to know what they are worth and where you are getting them from.
GTI16V
CROMER, NSW
Re: 4AGE 100kw Cams Wed, 24 August 2005 07:29 Go to previous messageGo to next message
They want $440 per pair of new billet cams plus delivery.
TRD-GTI
Elwood, Melbourne
May 2005
Re: 4AGE 100kw Cams Wed, 24 August 2005 10:38 Go to previous messageGo to next message
do you know what spec no. the 262 Wade cams are? was it 1056a or 956a? just curious coz Im getting some soon, but havent been down there to discus yet.
I would go up to 272 max on std ecu like the others have said. new billet should be the only way you go. regrinds arent good
GTI16V
CROMER, NSW
Re: 4AGE 100kw Cams Wed, 24 August 2005 11:11 Go to previous messageGo to next message
They were for the 872a ones.
TRD-GTI
Elwood, Melbourne
May 2005
Re: 4AGE 100kw Cams Wed, 24 August 2005 12:01 Go to previous messageGo to next message
true, they are the basic upgrade ones ay? if I were spending the money (which I am soon) I would get the lumpier ones for the same money coz they will still run ok with ecu. maybe look at some valve springs too if you increase the lift a bit
TE72_Turbo
Re: 4AGE 100kw Cams Wed, 24 August 2005 13:49 Go to previous messageGo to next message
DO NOT try to run the Wade 1056a cams without a shim-under conversion kit, you will spit the shims.
The 872a grind are fine though, they don't have the extra lift. I run them in my motor currently.
Phil
takai
Re: 4AGE 100kw Cams Wed, 24 August 2005 14:35 Go to previous messageGo to next message
Nah, while 0.338" is getting close to shim spit levels, its still ok, barely.
Im running 0.35" and still waiting for it to spit a shim, admittedly i am changing to solid lifters.
TE72_Turbo
Re: 4AGE 100kw Cams Wed, 24 August 2005 22:19 Go to previous messageGo to next message
You've run the 0.338" have you?
Its not just about the lift, its about the ramp profile also.
I have fitted the 1056 cams to my motor, and can get the shims to lift off the bucket on one side turning the engine over BY HAND - so what do you think they'll do at 7000rpm? Shocked
[Updated on: Wed, 24 August 2005 22:20]
takai
Re: 4AGE 100kw Cams Wed, 24 August 2005 22:56 Go to previous messageGo to next message
Im running 0.35" lift, at somewhat more aggressive ramp than the Wade cams i have seen.
I havnt seen the 1056's though, so it could be different.
rallysprinter
Hobart
Re: 4AGE 100kw Cams Thu, 25 August 2005 03:44 Go to previous message
I've just put a pair of 288 degree 7.5mm lift Wade billets in my Bigport 4AGE and I'm very happy with them. But I run a 5.3:1 diff and microtech but still the standard manifold for the moment.
I pulled out the standard cams, replaced them with the billets, re-shimmed, re-tuned it and gained 8 rwkw and an extra 1300rpm of useable rev range. Still is quite drivable from about 2,800rpm onwards and has a very slightly lumpy idle at 1200rpm. It's got a bit of a dip in torque between 4,500 and 5,500 but temporarily removing the pod filter made that go away but it's back on now until I get the quads on.
Previous Topic:AE102 performance options?
Next Topic:7M-GTE Manual/Auto ECU pinout query
Current Time: Tue Nov 17 15:47:33 UTC 2026
Total time taken to generate the page: 0.024029970169067 seconds
