Toymods » Tech & Conversions » Replacing wheel studs
KOFFEE-BLACK
Replacing wheel studs Wed, 24 August 2005 00:21 Go to next message
Are there any write ups about replacing wheel studs? Im going to give this a go myself on the weekend. From my understanding, its as simple as taking the wheel off, unbolting the brake caliper, taking the disc off, and knocking out the stud? Any more info would be handy.
Cheers!
Toobs
Re: Replacing wheel studs Wed, 24 August 2005 02:27 Go to previous messageGo to next message
Yep thats it...
1. Remove wheel.
2. Unbolt caliper.
3. Tap off disc with rubber mallet or similar.
4. Bash out old studs
5. Bash in new studs (or use the an old rim to pull them into place)
6. Reverse steps 1-3.
Its much nicer if you actually unbolt the hub because you can get to the rear of the studs easier, however, most people just do it while the hub is still bolted to the car.
KOFFEE-BLACK
Re: Replacing wheel studs Wed, 24 August 2005 07:52 Go to previous messageGo to next message
cool thanks! Also, I found a guide, on the tourqe settings each nut should be tightened at, my car is 103, wtf does this mean? (Dumb question??)
styler
Re: Replacing wheel studs Wed, 24 August 2005 09:34 Go to previous message
err torque as in the amount of force used to tighten them up, measured with a torque wrench. for wheel nuts i wouldnt bother, id just do them up as much as i can with the the wheel spanner.
http://www.justtools.com.au/prod2171.htm
[Updated on: Wed, 24 August 2005 09:36]
Previous Topic:Boost guage install
Next Topic:Help Check engine light!
Current Time: Fri Nov 20 21:26:53 UTC 2026
Total time taken to generate the page: 0.005446195602417 seconds
