Toymods » Tech & Conversions » RA40, NEED ADVICE ON ENGINE SWAP
maiku
Geelong, Vic
RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 01:45 Go to next message
iv asked this all ready, but I didn't get a satisfactory answer,
SO ILL ASK IT AGAIN
how hard is it to fit a SR20 in to a ra40 engine bay, iv heard its as simple as turning an engine mount up side down, has any one tried this in a celica of similar build
and b4 u all have a go at me iv considered all my posibilities (1jz, 1uz, 18rg, 4age, and the SR turns out the cheapest)
any help would be helpfull
Re: RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 01:55 Go to previous messageGo to next message
I seriously doubt it's that easy. I've seen an SR20 in an RA28 Celica and the engine mounts were totally custom. They also used a TA23 crossmember to match the SR20's front-sump layout.
Be aware that the engine mounts are the least of your worries. Physically mounting the engine is the easy part; the difficult/expensive stuff comes after that!
Re: RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 02:32 Go to previous messageGo to next message
The Witzl's bodgy list of custom items you will need for SR20 conversion....
# custom tailshaft
# custom gearbox crossmember
# custom engine mounts
# possible modify transmission tunnel
# custom diff + diff mounting
# custom brake upgrade
# custom engineering
# custom cooling system
# custom dump pipe and exhaust
# custom intercooler piping
the custom list goes on and on.... with each of the above costing on average $1000 - thats over $10k there!
SR20 a cheap conversion??? i think not
Re: RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 02:57 Go to previous messageGo to next message
maiku wrote on Wed, 24 August 2005 11:45
and b4 u all have a go at me iv considered all my posibilities (1jz, 1uz, 18rg, 4age, and the SR turns out the dearest)
fixed...
seriously: the cheapest conversion for an RA40 would be an 18R-gue, followed by the 1G-gte.
The 4age would be a high-revving screamer (to get the power to shift a heavy ra40 around) and the other 2 would be too large in capacity for an RA40 (in Qld).
I've seen what i think was an SR20DET in a sprinter at Willowbank at the '04 Jamboree. It looked like a very busy and well stuffed engine bay. When i get home i'll try to find and post a pic.
Perhaps the answers were satisfying the requirements of the question, but not your expectations?
cheers,
Charles.
maiku
Geelong, Vic
Re: RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 05:26 Go to previous messageGo to next message
thanx Witzl, i was thinking a long those lines but i wasnt exactly sure.
it wont actually cost me that much, a mate of mine has his own shop so getting the engine and box in and connected wont be such a problem, the exhaust and cooler piping is wot wories me coz dats one thing he cant do.
CelicaRA45
nth ringwood, Victoria
Re: RA40, NEED ADVICE ON ENGINE SWAP Wed, 24 August 2005 10:08 Go to previous messageGo to next message
or you could put in a 3sge motor like i have done
Re: RA40, NEED ADVICE ON ENGINE SWAP Thu, 25 August 2005 07:01 Go to previous messageGo to next message
maiku wrote on Wed, 24 August 2005 15:26
Ok, so of the 10 items on my list... you have eliminated the CHEAPEST two, and were aware of two others.... that leaves $6000 you arent prepared for by my dodgy $1000/item formula - but thats not taking into account most of the 6 items left will be $1500-2500....
SR20DET - NOT CHEAP.
Corona_82
Bella Vista
Re: RA40, NEED ADVICE ON ENGINE SWAP Thu, 25 August 2005 08:43 Go to previous messageGo to next message
My best mate has a SR20 in his RA40, got it done bout 2 months ago, cost $2500 for front cut s15 which had done 19k, all up incl ST185 GT4 brakes all round and VL turbo fuel pump etc cost him $8k. Custom engine mounts on the r series x member, radiator moved foward, piece of the underside of the bonnet taken out to accomodate the cam cover, custom tail shaft, new gear shifter position (further back). It flies
brett_celicacoupe
townsville NQLD
Re: RA40, NEED ADVICE ON ENGINE SWAP Fri, 26 August 2005 11:59 Go to previous message
ill be looking at about 2K - 2.5K all up for my 1g-gte conversion.
thats doing ALL work myself
i reckon i could have had it comepletely swapped and engineered within 2 weeks if i didnt bother making things neat, polished and pretty Razz
brett
Previous Topic:car died...
Next Topic:4agte Flywheel information
Current Time: Thu Nov 19 06:08:06 UTC 2026
Total time taken to generate the page: 0.0053350925445557 seconds
