Toymods » Tech & Conversions » ---Help NEEDED identifying engine production year---
DRAG-DIS
August 2005
---Help NEEDED identifying engine production year--- Wed, 24 August 2005 01:59 Go to next message
HI Guys,
I have an import 1ggte, i need to know what year it was manufactured, so i can order parts for it.
Can anyone help?
The engine number is
1G 9262948
THANKYOU
Wink
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 02:17 Go to previous messageGo to next message
check the ignition leads... if they are the factory toyota ones they will have a date stamp on them Smile
DRAG-DIS
August 2005
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:13 Go to previous messageGo to next message
Thanks , but they arent the standard leads, they have been changed.
Can anyone help, please?
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:26 Go to previous messageGo to next message
Few questions:
Why do you need to know the manufacture year to buy parts for it?
What sort of parts do you want to buy?
What colour are the injectors?
DRAG-DIS
August 2005
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:28 Go to previous messageGo to next message
To order parts for it, like a gasket kit, and a woodriffe key, i need to know the production year cause apparentally they are different, that is what the guy at castlehill toyota said.
I am unsure of the colours of injectors i will have a look
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:34 Go to previous messageGo to next message
Find out the injector colour, that'd be a good start, then we can narrow it down to a Gen2 or a Gen3. (Or if it has a water/air cooler it's a Gen1).
What gaskets are you chasing?
Why are you replacing the woodruff key? Is it f**ked?
DRAG-DIS
August 2005
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:39 Go to previous messageGo to next message
Hey mate
Thanks for your help, i appreciate it!
We are just replcaing everythign pretty much, dont know why, just better to be safe then sorry i guess.
I am chasing an inlet, exhaust, cam seals, cranks seals for the timing cover. do you have an alternative place i can find these?
ANyway the injector colour is yellow, does that help?
thanks for your help again!
Re: ---Help NEEDED identifying engine production year--- Wed, 24 August 2005 03:48 Go to previous message
I was fairly precautionary when I did mine, but there is a limit to just how much maintenance I felt was required.
You should be able to tell the dealer it's from a GA70 Supra from pre-88, as yellow injector plugs is a Gen2 engine. I wouldn't really be getting anything from a dealer I didn't have to though, and for me that'd only be the cam cover gaskets.
I personally wouldn't touch the inlet or exhaust gaskets unless there is currently a problem with them. Cam cover seals are $50 each trade. Seals for the timing cover I just made from squished vacuum hose, not that they actually seal anything.
I changed the oil pump seal, the front and rear main seals, the cam seals and eventually the waterpump (although I think the non-existent gasket was the problem there. Just remove these oil seals and take them to a bearing place and match them up. If they're original, they'll be made by NOK and have their part #'s on them. Same seals will cost you about 4 times as much from dealership.
Hope that helps dude.
Previous Topic:non toyota Q about PCD and OFFSET
Next Topic:price of bolting 4age into ae82 corolla CSX
Current Time: Fri Nov 20 20:52:03 UTC 2026
Total time taken to generate the page: 0.1300950050354 seconds
