Toymods » Tech & Conversions » 3SGTE Dipstick problem
Brenton_TA23
3SGTE Dipstick problem Wed, 24 August 2005 07:42 Go to next message
I need some help.
I have a GT4 165 with a dipstick that is too long to go all the way into the holder. This means it doesn't make a seal.
I was having some oil leak problems so i wanted to rule this out and i got a dipstick from a 3SGE, which is heaps shorter, and it fits in the hole right.
Long term problem is i cant check my oil properly.
Can i use a dipstick from a ST162 for my ST165? ie do they have the same block, sump combo so can I use the 3SGE dipstick?
Also how much oil does the 3SGTE take? is it close to the 3SGE
I'm due for a change and by putting in the right amount i can see which dipstick shows the right readings.
And yes i'm possitive that the orig dipstick doesn't fit, i've tried it from heaps of angles. No go.
Thanks for any input
billmchenry
Fraser Coast, QLD
June 2005
Re: 3SGTE Dipstick problem Wed, 24 August 2005 08:32 Go to previous messageGo to next message
the 3sgte dipstick is a very tight fit. it should fit in.
I find on my 3sgte angle the loop of the handle toward the alternator, push it in a bit and then angle it toward the block.
I know that the 3sge one is longer. The only solution is using the 3sgte one, from my opinion neway...
ty
berad
Re: 3SGTE Dipstick problem Wed, 24 August 2005 08:55 Go to previous messageGo to next message
yer its toight Razz... takes a bit to get it in give it a bit of shove and a push Razz
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 3SGTE Dipstick problem Wed, 24 August 2005 09:15 Go to previous messageGo to next message
berad wrote on Wed, 24 August 2005 18:55
GET IN THE HOLE, YOU TOO GOOD FOR YOUR HOLE!!! Laughing
-=DV=-
Newcastle, NSW
Re: 3SGTE Dipstick problem Wed, 24 August 2005 14:02 Go to previous messageGo to next message
if u look at ur dipstick man u should notice its got a twist halfway down...., the 3sge ones dont from memory, id say it has something to do with trying to make it easier to get to because of the positioning of the turbo on the 3sgte...so i dont think a 3sge one will really solve your problem..u just have to be patient...persistant, and u have to know how to cuss in atleast 5 languages to get the fucker in
Brenton_TA23
Re: 3SGTE Dipstick problem Thu, 25 August 2005 07:41 Go to previous messageGo to next message
Yeah you were all right. Cheers for ya help fellas.
I also found info saying 3SGTE takes 4.5 litres of oil to fill including filter. Correct me if i'm wrong.
Also does anyone know a good place (website) to get specifications and info like that coz i can't get a GT4 manual or that type info without searching the net for hours.
Cheers again guys. Cool
berad
Re: 3SGTE Dipstick problem Thu, 25 August 2005 07:42 Go to previous messageGo to next message
youll find recomened oil doesnt line up with the dipstick well doesnt on mine anyway lol my dipstick says oil should be spewing out the head somewhere Razz but it has the right amount in
havabeer
new castle
July 2005
Re: 3SGTE Dipstick problem Fri, 26 August 2005 07:48 Go to previous messageGo to next message
check your libary for a manual... my local libary has my 3s-ge manual for when ever i want it....saves me 30 - 40 bucks Very Happy
Brenton_TA23
Re: 3SGTE Dipstick problem Mon, 29 August 2005 09:15 Go to previous messageGo to next message
Laughing He He He. No doubt they do.
Give ya a hundred bucks if they have one for a 3S-GTE.
Brenton_TA23
Re: 3SGTE Dipstick problem Mon, 29 August 2005 09:24 Go to previous message
No Message Body
[Updated on: Mon, 29 August 2005 09:25]
Previous Topic:Rolla Brakes
Next Topic:4agze dizzy question
Current Time: Wed Nov 18 17:02:30 UTC 2026
Total time taken to generate the page: 0.0053329467773438 seconds
