Toymods » Tech & Conversions » pumping out crankcase fumes
bassy
pumping out crankcase fumes Wed, 24 August 2005 11:36 Go to next message
Had a bit of an idea, and was just wondering if it would be practical... If im using an electric fuel pump, the stock diaphram type is free... could this be hooked up to the hole for the pcv valve and then pumped into an oil catch can? Technically this would remove All emissions and faster?
any thoughts?
terra
July 2005
Re: pumping out crankcase fumes Wed, 24 August 2005 11:42 Go to previous messageGo to next message
isnt that what intake vacuum is for?
bassy
Re: pumping out crankcase fumes Wed, 24 August 2005 11:47 Go to previous messageGo to next message
intake vaccum stops when the carby is fully open. and the emmisions go back into the system. Its basically like using an oil catch can cept a catch can has no vaccum, the pump would suck it all out
feral4mr2
Bundaberg, Qld.
Re: pumping out crankcase fumes Wed, 24 August 2005 12:38 Go to previous message
my friend uses a vacuum pump on his chevy drag engine, he says it can helps seal his rings and free's up some HP.
http://www.gzmotorsports.com/vacuum-pump-guide.htm l
http://www.dragstuff.com/techarticles/vacuum-pumps .html
Previous Topic:supra spare tyre
Next Topic:1jz power steering cavitating?
Current Time: Wed Nov 18 19:25:48 UTC 2026
Total time taken to generate the page: 0.0045139789581299 seconds
