Toymods » Tech & Conversions » Stripped Steering Rack Bolts...
ZZT231
melbourne.vic.au
Stripped Steering Rack Bolts... Thu, 25 August 2005 03:15 Go to next message
Hey All,
How should I fix the stripped steering rack bolts legally and strong enough?
Cheers.
Re: Stripped Steering Rack Bolts... Thu, 25 August 2005 07:16 Go to previous messageGo to next message
Which bolts?
Henn
Rosanna, Melb
Re: Stripped Steering Rack Bolts... Thu, 25 August 2005 12:28 Go to previous messageGo to next message
If they are the bolts which hold the rack to the crossmember I'd suggest drilling and tapping out to a larger thread and using a slightly larger bolt. There should be enough material in the threaded nuts to cope.
I guess they'd be M8 x 1.25 (top of head) and so there may be something slightly bigger in imperial that'd do.
Or cut the old rooted threaded parts out and weld in a few nice new nuts and use new bolts.
If its anything else I guess I can't help.
Hen
ZZT231
melbourne.vic.au
Re: Stripped Steering Rack Bolts... Thu, 25 August 2005 14:39 Go to previous messageGo to next message
Thanks for the post guys. Henn you are right, it's the rack mounting bolts Razz
I'll see what I can do on the weekends...
Cheers.
Re: Stripped Steering Rack Bolts... Fri, 26 August 2005 00:35 Go to previous message
If you only stuffed the bolts, just get new ones.
If you stuffed the nuts too, you'll need to replace the crossmember, or tap out the welded nuts.
Previous Topic:SERIES Twincharging... (no longer taking the piss :P )
Next Topic:hiace go fast
Current Time: Wed Nov 18 10:43:56 UTC 2026
Total time taken to generate the page: 0.0065829753875732 seconds
