Toymods » General Car Talk » Brake fluid recommendations
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Brake fluid recommendations Thu, 25 August 2005 04:01 Go to next message
Hey all,
After a spirited drive in the mountains around Canberra, I've managed to boil the brake fluid in the Liberty*.
Any recommendations on a brake fluid? I'm prolly gonna go for Dot 4 stuff. Maybe Dot 5, who knows.
* Well I think I've boiled it. Pedal has gone long and braking is very inconsistant. Sometimes it's good, other times bad.
[Updated on: Thu, 25 August 2005 04:02]
4agte
Toronto, Downtown
Re: Brake fluid recommendations Thu, 25 August 2005 04:21 Go to previous messageGo to next message
dot 5 is corrosive to rubber if i remember correctly so i would steer clear of it unless you have steel brake lines..
Dot 4 is fine i brake pretty hard and on the track with dot 4 ive never had any troubles whatsoever
Re: Brake fluid recommendations Thu, 25 August 2005 05:10 Go to previous messageGo to next message
Dot 5.1 is fine as it's not silicon based. That said, the Castrol Super Response Dot 4 seems highly recommended and beats most of the ones I compared it to on specs by a lot.
Youngy
Eskilstuna, Sweden
Re: Brake fluid recommendations Thu, 25 August 2005 05:11 Go to previous messageGo to next message
Motul RBF 600 hands down.
Nark
Cabramatta, NSW
Re: Brake fluid recommendations Thu, 25 August 2005 05:15 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 25 August 2005 15:10
Yeah, I've used this for years in the Celica and would be my choice.
Just thought I'd ask and see other peoples' opinions.
Re: Brake fluid recommendations Thu, 25 August 2005 05:19 Go to previous messageGo to next message
Youngy wrote on Thu, 25 August 2005 13:11
...although this looks pretty damn good.
Toobs
Re: Brake fluid recommendations Thu, 25 August 2005 05:23 Go to previous messageGo to next message
DOT 5 is silicon based and has different properties to the glycol based dot 3 / 4 fluids.
DOT 5.1 however is glycol based but has the boiling point of DOT 5 fluids... i.e. its just a DOT 4 fluid with boiling point of DOT 5.
Find out what DOT 5.1 fluids you can get your hands on and then check their wet / dry boiling points.
Motul is one of the best DOT 5.1 fluids that is commonly available IIRC.
Nark
Cabramatta, NSW
Re: Brake fluid recommendations Thu, 25 August 2005 06:12 Go to previous messageGo to next message
Alright. Some numbers would be good to look at.
Name           Dry BP  Wet BP  Vis -40  Vis 100
Dot 3:           205    140      1500     1.5
Dot 4:           230    155      1800     1.5
Dot 5:           260    180
Motul RBF600:    312    216      1720     2.5
Motul 5.1:       270    185       820     2.1
Castrol S.R.:    286    184      1250     2.5
Castrol SRF:     310    270       130     3.5
Nulon Xtreme:    286    184      1231     2.5
Wilwood 570:     299    140
Wilwood 600:     330    214
Spec sheets:
Motul RBF600
Motul 5.1
Castrol Response Super Dot 4
Castrol SRF
Nulon Xtreme
[Updated on: Thu, 08 September 2005 06:20]
monkeymajik
Re: Brake fluid recommendations Fri, 26 August 2005 15:59 Go to previous messageGo to next message
Nulon Xtreme is supposed to be good without costing the earth (for brake fluid)
kingmick
Banned by his request
moved to tamworth
Re: Brake fluid recommendations Sat, 27 August 2005 01:30 Go to previous messageGo to next message
just get same wilwood brake fluid nark!$15 a bottle and works very well in the race cars.or AP at $90 which isnt really needed on the street.
mick
Nark
Cabramatta, NSW
Re: Brake fluid recommendations Thu, 08 September 2005 04:50 Go to previous messageGo to next message
Mick, where can I get that Wilwood stuff?
Castrol Response Super is ~$10/500mL from Supercheap.
The RBF 600 is ~$25/500mL from Shift Motorsport in Lansvale.
I can't see the RBF 600 being 2.5 times better than the Response Super (which already exceeds Dot 5 standards), so I think I'll be sticking with the Castrol.
ke382TG
Re: Brake fluid recommendations Thu, 08 September 2005 04:58 Go to previous messageGo to next message
Thats what I have been running, I had no problems at the last track day using this (my car is pretty light though so doesn't work the brakes too hard).
Gave it a good workout a few weeks back and it was fine then too (hills and motorkhana stuff).
Actually it's been the same fluid in the system for just over 12 months now Embarassed I'm a lazy turd.
kingmick
moved to tamworth
Re: Brake fluid recommendations Thu, 08 September 2005 05:02 Go to previous messageGo to next message
austrack motorsport at 109 airds rd minto!i dont know who else carries it. 98204255
mick
Nark
Cabramatta, NSW
Re: Brake fluid recommendations Thu, 08 September 2005 06:23 Go to previous messageGo to next message
Updated the table with the Nulon and Wilwood stats that I could find.
Nulon Xtreme is $8/500mL from Supercheap.
Called up Austrack and these are the prices:
Wilwood 570 is $15/375mL (which works out to be $20/500mL)
Wilwood 600 is $66/500mL
The Castrol and the Nulon are very close in numbers and the Nulon is even cheaper than the Castrol!
I think either one of those two would be my choice. Probably the Castrol for me since I've been using it for years in the Celica anyway.
The rest are a lot more expensive and I doubt I'd need that sort of performance. I'm sure I'll find out if I do though! Very Happy
[Updated on: Thu, 08 September 2005 06:33]
kingmick
moved to tamworth
Re: Brake fluid recommendations Thu, 08 September 2005 07:35 Go to previous messageGo to next message
the wil570 is fine.i have sold cases of it,if it does the job in a state level sportsedans etc etc.the 600 is for stuff like our cars that brake from 300km\h with brembo 12 spotters and soft pads that last a weekend.
mick
Joshstix
Toymods Vice President
Re: Brake fluid recommendations Thu, 08 September 2005 08:24 Go to previous messageGo to next message
kingmick wrote on Thu, 08 September 2005 17:35
mick
I dunno.
Sure I can see that stuff being fine in a race car that gets all the fluids changed religiously but with a wet boiling point of 140 degrees I think it could have issues in a road car. Most road cars don't tend to have the brake fluid changed as often as they should so, I'd suggest something with a higher wet boiling point or a really strict maintainance schedule.
[Updated on: Thu, 08 September 2005 08:24]
kingmick
moved to tamworth
Re: Brake fluid recommendations Thu, 08 September 2005 09:04 Go to previous message
i use ap600
‘Typical’ New Dry Boiling Point in excess of - 300°C (572°F)
‘Wet’ E.R. (Equilibrium Reflux) Boiling Point - 210°C (410°F)
i use the ap600 becuase i have a case of it(it costs between $90-$120 for 500mls from memory),but ive used the wil570 with no problem.change it every 6 months or so.
mick
Previous Topic:143 cents is too much
Next Topic:worst day ever
Current Time: Thu Nov 19 14:37:29 UTC 2026
Total time taken to generate the page: 0.013411045074463 seconds
