Toymods » Tech & Conversions » Detonation on 4agze turbo
avante123
South Africa
August 2005
Detonation on 4agze turbo Thu, 25 August 2005 07:25 Go to next message
Need some help as to what causes detonation broke my motor twice same problem detonation on pistons could it be timing , fuel,turbo or the piston i am using the normal super charge forge piston .
http://i14.photobucket.com/albums/a302/caddy123/25082005003.jpg
4agte
Toronto, Downtown
Re: Detonation on 4agze turbo Thu, 25 August 2005 07:38 Go to previous messageGo to next message
must have been knocking pretty bad...
give us more details of your setup
edit:
My guess and its a guess is that it was from too much timing or crap fuel...
[Updated on: Thu, 25 August 2005 07:39]
Rex_Kelway
Re: Detonation on 4agze turbo Thu, 25 August 2005 08:21 Go to previous messageGo to next message
avante123 wrote on Thu, 25 August 2005 16:55
Need some help as to what causes detonation...could it be timing, fuel, turbo ...
Congratulations, you have answered three very correct responses to your own question.
Add also, combustion chamber efficiency, hot-spots, A/F-R, inlet temps.
More information is needed. EG is it well tuned on awesome fuel and using 70deg advance at full load/revs?
[Updated on: Thu, 25 August 2005 08:24]
avante123
South Africa
August 2005
Re: Detonation on 4agze turbo Thu, 25 August 2005 08:35 Go to previous messageGo to next message
I have a standard 4agze motor
t3/t4 dash 2 exhaust wheel and housing
i was using standard fuel the mech says it was the turbo boosting too high about 1.2bar that's why it detonated .
4agte
Toronto, Downtown
Re: Detonation on 4agze turbo Thu, 25 August 2005 09:07 Go to previous messageGo to next message
is this in an mr2 by any chance???
my guess is it leaned out then
Re: Detonation on 4agze turbo Thu, 25 August 2005 14:16 Go to previous messageGo to next message
step 1. get aftermarket engine management
step 2. get it properly tuned
step 3. get new GZE pistons + rings from toyota
step 4......
step 5. profit
feral4mr2
Bundaberg, Qld.
Re: Detonation on 4agze turbo Thu, 25 August 2005 20:50 Go to previous messageGo to next message
it's wierd it broke out there than lifting/curving/breaking up the top ring land first.
yea an aftermarket engine management set-up is best (and properly tuned like mentioned) if you want to run high amounts of boost, and a good i/c set-up.
though i am having better luck useing my 9.4:1 casties than i did with the gze forgies.... Razz
10sec_rx7
Syndey
Re: Detonation on 4agze turbo Fri, 26 August 2005 03:40 Go to previous message
feral4mr2 wrote on Fri, 26 August 2005 06:50
must be something with toyota 9.4:1 cast pistons, i have pushed my 4efe to 21psi and still going stong Smile
Previous Topic:Aftermarket bushes for mx83
Next Topic:1jz Cressida auto problems
Current Time: Sun Oct 18 00:16:06 UTC 2026
Total time taken to generate the page: 0.0053339004516602 seconds
