Toymods » Tech & Conversions » TA22 Diff in T-18 diff housing
roids70
Tasmania, Evandale
April 2005
TA22 Diff in T-18 diff housing Thu, 25 August 2005 09:06 Go to next message
Will a Ta22 Diff setup go strait into the T-18 diff housing, does it bolt strait onto it, or is there som converting to be done, wot has to be dont to also install the diff in.
Cheers Sean
sxr01r
The Hills District
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 10:08 Go to previous messageGo to next message
howdy, the diff center will be a straight swap, im not sure about the whole setup. im not too sure but id say that the t18 has bigger brakes anyways so it would be better to just use the center. either way the t18 center is a better center.
roids70
Tasmania, Evandale
April 2005
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 10:13 Go to previous messageGo to next message
well correct me if i wrong, but would it be better to have the TA22 diff with a ratio of 4.1:1 or the T-18 diff ratio of 3.9:1, and i dont really understand how they work in a diff i just got told a TA22 diff picks up speed quickly compared to the T-18 diff.
Cheers Sean
KOPDIS
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 10:27 Go to previous messageGo to next message
almost positve the TA22 bolts straight into the T18 rear end, they are both Tseries diff housing's.
Do a search in the tech section im sure its been covered many times before otherwise ask a wrecker they know
koen
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 11:07 Go to previous messageGo to next message
I seem to remember reading somewhere that the bolt hole spacing on the tailshaft flange is different between the T18/AE86 diff and the Celica T-series? I could be wrong, but it might be worth checking...
AEHachiRoku
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 12:27 Go to previous messageGo to next message
The TA22 centre does bolt straight into the T18 housing as they are both Tseries diffs.
Ive got a locked TA22 centre in my 86.
Craig
Re: TA22 Diff in T-18 diff housing Thu, 25 August 2005 23:37 Go to previous messageGo to next message
Be careful, early TA22's have a D series diff.
roids70
Tasmania, Evandale
April 2005
Re: TA22 Diff in T-18 diff housing Sat, 27 August 2005 08:58 Go to previous messageGo to next message
Cheers Guys will ceep my eye on all these thing making sure i look at every thing befor i stuff up
Sean
Sam_Q
S.E suberbs, Vic
Re: TA22 Diff in T-18 diff housing Tue, 30 August 2005 12:57 Go to previous message
I also did this, the only difference is that one or two of the bolts of the ta22 diff center need to be used because the t-18 ones are longer in one spot.
Previous Topic:4AGE Inlet Question
Next Topic:2tg NA what do i expect?
Current Time: Sat Oct 17 21:26:25 UTC 2026
Total time taken to generate the page: 0.017885208129883 seconds
