Toymods » Tech & Conversions » Unusual Headlight Drama
TheStitt
Membership Secretary
Unusual Headlight Drama Tue, 24 December 2002 21:46 Go to next message
G'day guys Ive got a strange problems with the headlights on my 68 crown. It has dual lights like the early celicas so I'm hoping one of you guys might of had it before.
What is happening is that when I put on high beam my left low beam light goes out and the left high beam doesn't come on at all. Both right lights are working as they should and the left low beam works as it should when on low beam.
To my knowledge the low beam and high beam circuits are separate so isn't it impossible for the low beam light to go out when high beam is selected???
Any thoughts would be appreciated
thanks Stitt
Re: Unusual Headlight Drama Wed, 25 December 2002 05:15 Go to previous messageGo to next message
I dont know what the Crowns are like but the Celicas have: 2 highs and 1 low on either side! Normally when you turn the high beams on the lows turn off!
Bugman
Re: Unusual Headlight Drama Wed, 25 December 2002 09:16 Go to previous messageGo to next message
first thing first.. clean up all the contcts in the clip on connections at the back of the light
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Unusual Headlight Drama Wed, 25 December 2002 10:06 Go to previous messageGo to next message
Yeah man, the lights with the low beams have 2 different elements in it, one for high & one for low. So when you switch to high this globe switches over plus the inner lights cme on.
That's why the inner high beam only lights have a 2 wire plug & the outers have 3 wires, 1 for high beam, 1 for low beam & 1 for earth.
So it's just a bodge connection somewhere to that side of the high beam.
gt20v
Re: Unusual Headlight Drama Wed, 25 December 2002 10:07 Go to previous messageGo to next message
yeah, Cool1 is right, when the high is on the low goes out, so looks like you have a blown bulb.. Razz or check the connection/wires of the high beam of the left light for corrosion, shorts, open circuit..
pull the bulb out, check light bulb, and if it's not blown, get a volt meter, check the voltage of the high beam connector in reference to ground, if no voltage, trace the wire down until you find any power, that way you'll find where the open circuit is..
TheStitt
Re: Unusual Headlight Drama Thu, 26 December 2002 08:18 Go to previous messageGo to next message
Thanks for the replies guy will sit down with those ideas and a few of my own and sort it out.
juzzo84
Hornsby, N.S.W
Re: Unusual Headlight Drama Fri, 27 December 2002 03:51 Go to previous messageGo to next message
JUST REMEMBER TO CHECK YOU EARTHS
JUZZO
TheStitt
Re: Unusual Headlight Drama Fri, 03 January 2003 02:15 Go to previous messageGo to next message
Thanks to every one that replied.
The problem was a faulty Fuse for the left side high beam.
That's what I thought was wrong but my dad confused me with the way he thought the lights worked. his way it wasn't the fuse.
GIN51E
Berowra-Sydney
Re: Unusual Headlight Drama Sat, 04 January 2003 22:22 Go to previous message
With my Celica i had a problem, when lights were on normal the left side light did not work, when i put it on to high beam the left side started working but one on the right side would then turn off,
fault being a had a blown low beam filament on the left side and a blown high beam filiment on the right side.
Previous Topic:how do i set up temp gauge in KE35 4AGE
Next Topic:Converting FWD 4AGE 100KW to RWD
Current Time: Sun Oct 25 17:04:57 UTC 2026
Total time taken to generate the page: 0.007627010345459 seconds
