Classifieds » Wheels, Tyres, Suspension and Brakes » Roll centre adjusters ae86
battlestar
June 2005
Roll centre adjusters ae86 Thu, 25 August 2005 11:32 Go to next message
I have a set of 45mm roll centre adjusters for sale $135 includes bolts and spring washers contact Beau 0403688809
Attachment: Battlestar44mm.jpg
(Size: 70.47KB, Downloaded 195 time(s))
battlestar
June 2005
Re: Roll centre adjusters ae86 Fri, 26 August 2005 10:32 Go to previous messageGo to next message
bump
drift-diablo
August 2005
Re: Roll centre adjusters ae86 Fri, 26 August 2005 10:58 Go to previous messageGo to next message
look good mate, cusco want over $260 for a set of 30mm rca's. Are 44's better then 30? they look very new!
chrisellis
Re: Roll centre adjusters ae86 Fri, 26 August 2005 13:39 Go to previous messageGo to next message
drift-diablo wrote on Fri, 26 August 2005 20:58
one would assume they are new for that price, 45mm rca's are technicly only suitable for a car lowered 45mm, in the same respect 30mm rca's are perfect for cars lowered 30mm. You really might wanna understand how these things work b4 getting some that are unsuitable for your application. Chris
decoyslikecurves
Re: Roll centre adjusters ae86 Fri, 26 August 2005 16:34 Go to previous messageGo to next message
You dont sell these as negative camber rca's as well do you? because I would buy then.
Rallystanza
Re: Roll centre adjusters ae86 Fri, 26 August 2005 23:27 Go to previous messageGo to next message
decoyslikecurves wrote on Sat, 27 August 2005 02:34
As above...If someone can make NCRA's in this thickness.
Jezza
Maurice c
Re: Roll centre adjusters ae86 Sat, 27 August 2005 15:54 Go to previous messageGo to next message
What exactly is the differece between regular roll centre adjusters and negative camber roll center adjusters. You can gauge how much adjustment from an RCA if you get under your car and look at the bottom arm. This should be horizontal. When you lower your car, this will be sitting with the ball joint end higher then the bottom arm bolt end. You just need to add enough to bring it back to the horizontal position. I think that is, anybody got anything to add?
monkeymajik
Re: Roll centre adjusters ae86 Sat, 27 August 2005 22:31 Go to previous messageGo to next message
The negative camber RCA's have offset holes
[Updated on: Sat, 27 August 2005 22:33]
KOPDIS
Re: Roll centre adjusters ae86 Sun, 28 August 2005 03:37 Go to previous messageGo to next message
monkeymajik wrote on Sun, 28 August 2005 08:31
which give you around 1" more front end track aswell as fixing bump steer
drift-diablo
August 2005
Re: Roll centre adjusters ae86 Sun, 28 August 2005 11:00 Go to previous messageGo to next message
well i got mine lowered but want to lower a lot more if it will help the handling. I seen some setup with double 30's stacked for 60mm, bit overkill, 30 not enough, 45 a good balance?
<[D2]>
June 2005
Re: Roll centre adjusters ae86 Fri, 02 September 2005 06:35 Go to previous message
still got them might be interested
Previous Topic:AE92 SX rear swaybar (stock) - adelaide
Next Topic:AE101 1995 Seca Stock Springs
Current Time: Sat Oct 31 18:46:22 UTC 2026
Total time taken to generate the page: 0.036487102508545 seconds
