Toymods » Tech & Conversions » Koni's on MA61
Koni's on MA61 Thu, 25 August 2005 13:12 Go to next message
To anyone who has put Koni's in an MA61, any chance you could share what part number you used front and back? I haven't had a lot of luck with catalogues etc. so far...
joorsh
Re: Koni's on MA61 Thu, 25 August 2005 15:02 Go to previous messageGo to next message
My usual parts place told me they'd been discontinued. Can anyone confirm this?
HyDrA
Adelaide, SA
Re: Koni's on MA61 Thu, 25 August 2005 15:28 Go to previous messageGo to next message
I'd imagine you'd need to go off and install koni's designed for other cars, like the SW20 rears can be put up front with spacers.
bbaacchhyy
Re: Koni's on MA61 Thu, 25 August 2005 22:15 Go to previous messageGo to next message
I installed Yellow sports adjustables on my car.
On the fronts I used RAV 4 ones, and they needed only a small washer at the bottom of the strut tube (I used RA60 strut tube as well).
On the rears I used MA70 rears, but they required a bit of work to make them fit. I had to install a spherical bearing in the bottom, and the top shock bolt is bigger on the MA70 vs the MA61.
Have a look in my members ride thread, there are some pics in there.
http://forums.toymods.org.au/index.php?t=msg&t h=43718&start=0&rid=3701&S=b7cea596ab2 75fac6a96bd2ddb5f65c3
I think the MX73 shares the same rear shock - check with CrUZsida.
From the Monroe catalogue, the AE86 rears have similar dimensions, and some in the States have used a BMW rear as well as a Mustang one, but I don't know the availability of them.
Ed_MA61 has used some Bilsteins in the rear of his, but not sure what other cars they suited.
Michael B
Corona RT142
Campbelltown
Re: Koni's on MA61 Fri, 26 August 2005 00:33 Go to previous messageGo to next message
Koni Shock Absorber
TOYOTA CELICA SUPRA 84/85
Code: #K862328
Price: AU$206.00 (Australian Dollars)
NOTE: Australian deliveries must add 10% GST
bbaacchhyy
Re: Koni's on MA61 Fri, 26 August 2005 00:42 Go to previous messageGo to next message
Corona RT142 wrote on Fri, 26 August 2005 10:03
Koni Shock Absorber
Code: #K862328
Is that fronts or rears ?
It is probably the low spec red's rather than the sport yellows like mine.
All my enquiries (and I enquired a lot) said that there were none availiable/listed in Aus, but that the smarter distributors worked out an equivalent.
Re: Koni's on MA61 Fri, 26 August 2005 00:44 Go to previous messageGo to next message
F+R is identical to MX73
Corona RT142
Campbelltown
No idea was just searching the whiteline online store, thats all that is listed doesn't say front or rears, maybe someone could give em a ring to find out. I'd pop into their HQ 5 mins from my house but its only open weekdays.
bbaacchhyy
Re: Koni's on MA61 Fri, 26 August 2005 01:00 Go to previous messageGo to next message
CrUZsida wrote on Fri, 26 August 2005 10:14
Wish I would have known that (as well as the suppliers).
Interestingly, I wonder if they are available in Yellow Sports, and what the respective damping rates are ?
Corona RT142
Campbelltown
Re: Koni's on MA61 Fri, 26 August 2005 01:06 Go to previous messageGo to next message
According to the whiteline site the MX83 is also compatible with the MA61 for kyb anyway
Toyota Cressida MX83Supra MA61 Frt
Code: #Y365076
Price: AU$168.18 (Australian Dollars)
hmmmmm.
They also list the Rav4 and cressida together.
Maybe its worth one of you guys giving them a call to see what they say.
ADDRESS:
Whiteline Automotive
4 Lincoln St
Minto NSW 2566
PHONE:
(02) 9603 0111
1800 040 003 (toll free)
int+ 61 2 9603 0111 (international)
FAX:
(02) 9820-2500
ORDERING METHODS:
Our products can be purchased via our secure Webstore (credit card only)
HOURS:
Normal opening hours (Australian Eastern Standard time):
Monday to Friday - 8.00am to 5.00pm
Stefan
Hobart, Tas
Re: Koni's on MA61 Fri, 26 August 2005 01:08 Go to previous messageGo to next message
AE86 is same as solid axcel A6 (I think), but is a lot shorter (like 3" IIRC) than the IRS shocks. Up front, rear sw20 mr2s work with a spacer, amoung heaps of other things. Fronts are easy, there are heaps of options.
I'm planning on using S13 rears in mine, I have a pair here and will taking out a stock shock & comparing if anyone is interested in pics.
If you want to spend a bit of money, you can buy a set of KYB Super Specials (externally adjustables, like KYB AGX) for about a grand delivered IIRC.
h3ff44
melbourne
February 2005
Re: Koni's on MA61 Fri, 26 August 2005 06:09 Go to previous messageGo to next message
i read the name and im like hahaha...
i was going to say "sorry dude dont think that they makes condoms that big"
well i found it funny.
good luck finding them pal.
ScreaminRolla
Campbelltown NSW
Re: Koni's on MA61 Fri, 26 August 2005 08:20 Go to previous message
861991-sport. These are what i have in my MA61 front struts, these are listed for just about all the early rwd toyotas
Previous Topic:18RG block with unknown Pistons(with close up pics)
Next Topic:tarago diff neeeed HELP
Current Time: Thu Nov 19 06:38:31 UTC 2026
Total time taken to generate the page: 0.016809940338135 seconds
