Toymods » Tech & Conversions » 3T-GTE oil leaks?
Toby
March 2005
3T-GTE oil leaks? Thu, 25 August 2005 14:30 Go to next message
Hi all,
I've searched long and hard, but I can't find any info in the forums about this....
I've recently purchased a Celica TA23 with a 3T-GTE engine. The car runs quite well, although it seems a little sluggish to take off. This is the first problem. and any suggestions would be great! I know very little about newer turbo engines, as ive only worked on the older 2T engines Smile
The engine seems in good condition and is fairly clean, although my main concern is a mate just spotted a large amount of builtup oil and gunk at the front of the engine just on and mainly below the 3T-GTE symbol plate, above the various belts etc...
Tomorrow i'm going to check to see if there is any oil in the coolant and degrease the engine, but are there any other ways of determining whether the head gasket is blown ? I've just spent all the money I had purchasing the car, so I really hope its not blown as I guess its going to be expensive... Sad
Any help would be really great.
Thanks in advance!
Toby
jackel
Re: 3T-GTE oil leaks? Thu, 25 August 2005 17:08 Go to previous messageGo to next message
do a compression test.
Also give us some pics of the car and engine Very Happy
Toby
March 2005
Re: 3T-GTE oil leaks? Fri, 26 August 2005 11:20 Go to previous messageGo to next message
Ok, Below is a link to some pictures.
http://www.arach.net.au/~thehive/celica/index.htm
I had to remove the fan shroud, radiator and fan before I could get into the damn thing. The 3T-GTE only just fits into the engine bay Smile
I also noticed that the radiator is completely dead. Its got leaks and rust all through it. That will be the first thing I will replace. Does anyone know where to get new ones ??? or would a good condition second hand one be a better idea ?? Whats models can you use ?
There was a hell of a lot of oil and dirt buildup around the pully area and as you can see from the pictures, completely caked over the 3T symbol, so much that I had to wipe it off with my finger.
After putting the radiator and fan back in I found that the engine is running rough when I accelerate, once it hits above 2500 revs its ok, but its very strange, and it only did that before when I ran out of fuel (I just filled it up tonight). It also gets very hot very quickly, which I assume is the fault of the radiator.
Its all very strange. I really need to take it to a mechanic, but I've got very limited funds... so I'd like to do as much as possible myself, before resorting to that.
Any help would be really great ?? Smile
jackel
Re: 3T-GTE oil leaks? Fri, 26 August 2005 15:42 Go to previous messageGo to next message
ewwwwwww that needs a good clean
if it's a ta22 radiator, just get a second hand one in good condition.
make sure you clean all the stuff cause if it drops on the crank pully n that it could damage the belts.
check all the vaccum hoses.
is this the oil cooled version? does it have a oil cooler?
what suburb you in i could come around and have a looksy? Smile
jackel
Re: 3T-GTE oil leaks? Fri, 26 August 2005 15:54 Go to previous messageGo to next message
hmm can you take a few pics of your whole engine?
is that a water pump i see on the left?
Toby
March 2005
Re: 3T-GTE oil leaks? Fri, 26 August 2005 16:20 Go to previous messageGo to next message
Yeah there are some hoses that really should be replaced. I'll get to em on sunday most likely. - Most of the general hoses, ie radiator, vacuum etc... are a little stiff etc...
I'm not sure if its an oil cooled version ? I suspect it would be because wern't they the stock standard out of the factory ?? Its got a second radiator in front of the engine radiator.. would that be the oil cooler ???
I'm in Yokine, WA (next to Mt Lawley). Your welcome to have a look. Any advice would be sweet Smile I just want to get it back into shape. The car has been restored previously by someone and the previous owner (after him) let it go a bit I think. This car diserves to be restored and looked after Smile
I'll take a few more pics of it tomorrow eve for ya Smile
Thanks again!
jackel
Re: 3T-GTE oil leaks? Fri, 26 August 2005 16:29 Go to previous messageGo to next message
i'm in Mirrabooka, 3t-gteu engines came either water or oil cooled and i've never seen a water cooled version, i don't know if yours is one cause it has a water pump or what i think is one?
best thing to do would be to degrease it, then take it for a good drive and then check if any oil is back, if any gaskets are stuffed i know a place in sydney that stock 3t-gte gaskets, it's where i got my one.
ohh and this is what your 3t-gte sign should look like Very Happy
http://img266.imageshack.us/img266/675/mvc007f8mk.jpg
Toby
March 2005
Re: 3T-GTE oil leaks? Sat, 27 August 2005 01:06 Go to previous messageGo to next message
I'm not sure whether its water or oil cooled.
I've cleaned the engine, and it now looks much better. I've taken it out last night, and today to work, so I'll see how much oil is back tomorrow.
If there is a fair bit of oil is it fair to assume that its the HG ??? If you have a minute do you think I may be able to bring it round for you to take a look at ?
The other thing I've found is that it runs out of fuel when the fuel gauge reaches just below the 1/2 way mark. I'm guessing its not drawing fuel from any lower than that ??? Any thoughts ?
Cheers!
p.s. oh yeah, the fan shroud is not essential to the cooling system is it ? I've taken it off until I get the new radiator in it.
jackel
Re: 3T-GTE oil leaks? Sat, 27 August 2005 10:47 Go to previous messageGo to next message
because theres oil doesn't mean it's the head gasket, it could be the rocker cover gasket, the 3t-gteu sign gasket or some other ones. Best bet is to wait a couple of days after you have driven it around and there check if and where the oil comes from.
you should put the shroud on cause it makes sure all the cooling from the fan goes into the radiator.
With the fuel gauge it could be a number of things. Easiest thing to check i think would be the fuel sender is properly in. I think the ta22 tank is behind the seat? dunno thats what i heard.
Have you got a compression tester? you can pick them up from like repco for like $20, it'll tell you each compression in each chamber and is the easiest way to tell if you have a blown HG Smile
Toby
March 2005
Re: 3T-GTE oil leaks? Sun, 28 August 2005 09:19 Go to previous messageGo to next message
I went and bought a compression gauge and did the test. It came out at 130 - 135 per chamber. And it went up in steps (to 130) in each stroke. I looked in the service manual and it said that the piston rings are shagged if that happens ? is that right ?
The manual listed the normal compression to be 171, although the manual mentions nothing about the 3T-GTE as its mostly about older engines and models like the original TA23 etc...
Do you know what the compression specs should be ?
The compression didn't seem to go down, and the manual suggested that if it stays its probably not the head gasket ??
The last thing is that 2 out of 4 spark plug holes were completely full of oil Sad I think its just the rocker gasket, as the ones which were empty had good seals at the top and the other two had bits of gasket flaking out.
Sheesh! I'm starting to regret paying $3900 for this car. On a good note, the body is in quite good condition, its just seems the engine is having trouble. Sad
Whats your thoughts ?
Thanks again Smile
[Updated on: Sun, 28 August 2005 12:34]
NAJJE
Re: 3T-GTE oil leaks? Sun, 28 August 2005 09:31 Go to previous messageGo to next message
Dont sweat mate... These are very rare engines and with some TLC, you will be extreamly happy once these problems are fixed. I just purchased a 3T-GTE that is being rebuilt now... Took me like 6months to find one.
Good Luck
Toby
March 2005
Re: 3T-GTE oil leaks? Sun, 28 August 2005 09:45 Go to previous messageGo to next message
Hey mate,
Thanks for the heads up Smile I've only owned the car for less than a week so naturally everything is up in the air.... until I work out whats exactly wrong with it and what I need to do to it.
I just need to find someone in Perth that can help me get it all done... any takers ??? Very Happy
Toby
March 2005
Re: 3T-GTE oil leaks? Sun, 28 August 2005 09:47 Go to previous messageGo to next message
No Message Body
[Updated on: Sun, 28 August 2005 10:09]
Toby
March 2005
Re: 3T-GTE oil leaks? Sun, 28 August 2005 10:06 Go to previous messageGo to next message
jackel wrote on Sat, 27 August 2005 01:54
Here's some pics of the whole engine.
http://www.arach.net.au/~thehive/celica/Engine11.JPG
http://www.arach.net.au/~thehive/celica/Engine12.JPG
Does it look like water or oil cooled ??
Smile
jackel
Re: 3T-GTE oil leaks? Sun, 28 August 2005 18:32 Go to previous messageGo to next message
hmm from them pics i dunno. Do you have a oil cooler at the front, if you don't know what that is, it's looks like a little radiator. from what i've read on here 135 is decent for a 3t-gte so i doubt its your head gasket.
Toby
March 2005
Re: 3T-GTE oil leaks? Mon, 29 August 2005 01:37 Go to previous messageGo to next message
Yep Its got a little radiator in front of the water radiator.
Sweet. I'm glad its not the head, but the gradual increasing of the compression on each stroke has got me worried about the piston rings.
As for the oil leaks, im pretty sure its the rocker cover and possibly one other gasket, although there is already oil on the block at the front, (same area) and im not sure where its coming from...
Before, you mentioned you had a site where you could get 3TGTE parts ??? can you tell me the URL ???? do they have other gaskets ?
Thanks again!
jackel
Re: 3T-GTE oil leaks? Mon, 29 August 2005 16:29 Go to previous message
The website below is where you can get all your gaskets from also dissy cap and other misc stuff, or you could just buy some gasket paper and make it yourself.
http://www.swmotorsport.com/
If your looking for parts, the selling part of this forum is proberly the best place in the world to find things for your 3t-gteu Smile
Previous Topic:Celica TA23 Caliper repair kit - bleeding nipples
Next Topic:Help - Corolla SX instrument wiring
Current Time: Fri Oct 23 16:33:53 UTC 2026
Total time taken to generate the page: 0.0065150260925293 seconds
