Toymods » Tech & Conversions » Do 15 inch steelies fit AE92 corolla ?
soo33y
Do 15 inch steelies fit AE92 corolla ? Thu, 25 August 2005 23:06 Go to next message
Hey,
I am thinking of putting on some 15 inch steelies on my Ae92 corolla so that I can put bigger rubber on.
I am thinking of using 205/60/15 tyres on them.
I need to know what size width rim I should be looking at and what offset ?
Will I have any problems running this size tyre and rim combo on my corolla ?
Daniel.
Leighp
NY
Re: Do 15 inch steelies fit AE92 corolla ? Fri, 26 August 2005 05:46 Go to previous messageGo to next message
i ride on 205/50/15s everyday and it is 2.5 in low and does not scrub a bit.
l
terra
July 2005
Re: Do 15 inch steelies fit AE92 corolla ? Fri, 26 August 2005 05:55 Go to previous messageGo to next message
slower acceleration Very Happy
thats about it ^^
4agte
Toronto, Downtown
Re: Do 15 inch steelies fit AE92 corolla ? Fri, 26 August 2005 05:56 Go to previous messageGo to next message
it would be easier and idealy better to buy a new set of alloy rims.. There are pleanty of them arround for ae92's you will require 4 x 100 in say a 38-42 offset i believe could be a bit more but either way if you buy something that came off an ae92 then you shouldnt have an issue..
twincam.org also has alot of rims for sale that suit corollas
edit: i wouldnt run a 60 profile try running a 55 or even 50 which will be much better
[Updated on: Fri, 26 August 2005 05:57]
soo33y
Re: Do 15 inch steelies fit AE92 corolla ? Sun, 28 August 2005 20:57 Go to previous messageGo to next message
My car is not lowered at all.
I know that using the 60 profile tyres will make the overall diameter larger than the standard tyres, but I have these tyres sitting around. Thought I might put them to good use.
Will they scrup on the guards at all ? Maybe on full lock ?
I'm gonna put them on tonight and see how they go.
terrykoun
Re: Do 15 inch steelies fit AE92 corolla ? Mon, 29 August 2005 01:33 Go to previous messageGo to next message
if you use the right offset, +38 it wont rub. Ive got +50 offset lowered 1.5" and that scrubs on full lock.
soo33y
Re: Do 15 inch steelies fit AE92 corolla ? Tue, 30 August 2005 21:30 Go to previous message
Ok, so the 205/60/15's don't fit the rear wheels.
The overall diameter of the tyre is too large as it does not fit under the spring mount. It is also too wide and rubs on the strut.
Are there any guys out there who are using 15 inch steelies from the later model corolla (not sure which one) ?
Are you using 195/50/15's?
How close are the tyres to the strut and the spring mount on the rears ?
Daniel.
Previous Topic:Fitting jza80 4-pots to jza70. NEED BRACKETS, who makes em??
Next Topic:'85 hilux.... 3t-gte....?
Current Time: Sat Nov 21 03:28:21 UTC 2026
Total time taken to generate the page: 0.0053229331970215 seconds
