Toymods » Tech & Conversions » 1mz-fe from camry or avalon in lexus rx330?
zaco_10
August 2005
1mz-fe from camry or avalon in lexus rx330? Fri, 26 August 2005 06:16 Go to next message
I have a lexus rx330 in Malaysia. The engine was damanged during a flash flood. Since the engine block has been damaged I was thinking of putting in a complete engine instead of repaiging it.
Would a 1mz-fe from a camry or avalon fit into the rx330 just fine? Are the mountings the same? Is there anything else I need to look into before doing something like this?
The car is a 2003/2004 model. Any info on what I can do or where to get engines would be appreciated.
Thank you
Zachary
Re: 1mz-fe from camry or avalon in lexus rx330? Fri, 26 August 2005 07:34 Go to previous messageGo to next message
Does the RX330 run a 1MZ or 3MZ?
If it runs a 1MZ you can use camry 1MZ, as long as it has all the same feature (VVTi etc)
Steve-AE86
Ademelaide, SA
Re: 1mz-fe from camry or avalon in lexus rx330? Fri, 26 August 2005 10:13 Go to previous messageGo to next message
lexus rx330 wouldn't run a 1mz, being a 3litre. lexus model names coincide with engine size, ie ls400 is 4.olitre, is200 is 2.olitre etc.
rx330 would then be 3.3litre, but it doesn't even say on the lexus.com site what the model code of the engine is.
check the build plate in the engine bay...it should say it on there somewhere.
Re: 1mz-fe from camry or avalon in lexus rx330? Sat, 27 August 2005 05:19 Go to previous message
It'll be a 3MZ.
1MZ might fit, but there will be a range of other issues to consider (thinking along the lines of integration of wiring). I'd imagine resale will take a good hit too.
Previous Topic:master/booster upgrade to suit GT-R brakes
Next Topic:1ggze Backfires on start up
Current Time: Wed Oct 28 00:40:47 UTC 2026
Total time taken to generate the page: 0.006331205368042 seconds
