Toymods » Tech & Conversions » TA22 Manifold hitting dizzy
mickandfel
Wentworthville
TA22 Manifold hitting dizzy Fri, 26 August 2005 09:15 Go to next message
I have fitted a redline twin carbie manifold to my 2T and the manifold and the solex carb is hitting the dizzy,has anyone else had this problem?
mickandfel
Wentworthville
Re: TA22 Manifold hitting dizzy Fri, 26 August 2005 21:22 Go to previous messageGo to next message
Surely someone has had this problem before?
mickandfel
Wentworthville
Re: TA22 Manifold hitting dizzy Sat, 27 August 2005 19:18 Go to previous messageGo to next message
Do you use a different dizzy? It is'nt going to work unless I grind some of the manifold and carbie away.
lilcrash
ipswich queensland
Re: TA22 Manifold hitting dizzy Sat, 27 August 2005 21:24 Go to previous messageGo to next message
sounds liek the same problem as with the stock efi. with it the elec dizzy wires hit the fuel rail and u cant retard it.
i woudl sugest a diffrent dizzy.
do u have a high or low dizzy??
yrhkira
June 2005
Re: TA22 Manifold hitting dizzy Mon, 29 August 2005 05:22 Go to previous messageGo to next message
mickandfel,
There should be no need for another distributor.
The solution is fairly easy. My "avatar" TA22 runs a 2T with a Mikuni dual sidedraught manifold and I have also come across this problem numerous times over the years.
With the distributor out look down into the hole with a torch.
You should see the drive gear on the camshaft and the top of the oil pump drive.
The slot in the oil pump is engaged by the end of the distributor.
The normal factory setting is to have the slot turned slightly counter clockwise from across the engine block. The distributor then will sit with the vacuum advance parallel to the block.
Turn the oil pump slot with a large flat ended screw driver clockwise so that the distributor engages with the vacuum advance at about 30 degrees around clockwise.
If this will not clear then try turning the slot further, or back the other way.
There are other tricks to tweak the standard dizzy if there is any interest.
There should be enough in the plug leads to do this.
If you could post a pic or two of the problem as it stands and
I can confirm all this.
Regards
Rodger
lilcrash
ipswich queensland
Re: TA22 Manifold hitting dizzy Mon, 29 August 2005 06:10 Go to previous messageGo to next message
sorry for hijacking your thread
im not sure about him but here is a pic of mine. my dizzy adjust bolt it sitting at about half way round.
http://img272.imageshack.us/img272/2207/11313546ni .jpg
thanx and laterdays
mickandfel
Wentworthville
Re: TA22 Manifold hitting dizzy Mon, 29 August 2005 11:25 Go to previous message
Thanks guys,I will have a tinker.
Previous Topic:Orange peel and other assorted questions
Next Topic:1JZ CONVERSION=wiring info. need pin-out diagram for MA70
Current Time: Tue Nov 17 21:04:53 UTC 2026
Total time taken to generate the page: 0.0062618255615234 seconds
