Toymods » Tech & Conversions » rebuild clutch master/slave cylinder
arasta
brisvegas
rebuild clutch master/slave cylinder Fri, 26 August 2005 09:21 Go to next message
somewhere in my clutchlines there is a leak. the time has come for me to put paid to the damn thing
i know where the master/slave cylinders are, and i have a vauge idea of what to do. specifics are what i am after. if someone has a scan of the relevant page in the Big Green Book or some pertinent advice on dumping the lines so i can get to the point of taking things apart, and then the best way of doing just that... please let me know Smile the first main thing is i have NFI where the bleed point /nipple is.. just to give you an idea where i am starting from :S
tis an Aw11 Aus delivered NA with C52 box, for reference. i already have the rubber bits for master and slave 'rebuild' kits and some advice already also but as i say more is welcome Smile
so...anyone done this one before then ? Smile
FWDCelica
sydney,nsw.oz.
Re: rebuild clutch master/slave cylinder Sat, 27 August 2005 07:51 Go to previous messageGo to next message
arasta wrote on Fri, 26 August 2005 19:21
Dude,
The slave cylinder is mounted to the gearbox.
Da bleed nipple is on the slave cylinder.
(the motor is in the back in case you didn't know)
Try bleeding it first even though it sounds like it's ready for new bits.
arasta
brisvegas
Re: rebuild clutch master/slave cylinder Sat, 27 August 2005 10:51 Go to previous message
mmm cool cool... must look harder as i didnt see the nipple on the slave first time. hm. glasses time mebbe? lol or mebbe just a good clean in there...
i *could* just bleed it again but i suspect it definitely is due time for a rebuild, its been a pretty slow leak for the past 2 years, just seems to have started going a lil faster now Neutral 88-05, 17 years of use and i doubt its ever been replaced or anything.
anyways i do know its suggested to check the bores internally once dissasembled, no use replacing the rubbers if the bores are all scratched and will let fluid past that way...
thought someone here would have at least some comment to say about it - but i found a guide for the slave here http://www.mr2mk1club.com/repairsp21.html and master cyl http://www.mr2mk1club.com/repairsp70.html here for reference. the mcyl kit i have is a pbr item, doesnt have the same parts unfortunately Neutral
see how we go
[Updated on: Sun, 28 August 2005 11:03]
Previous Topic:1j questions
Next Topic:recommended fuel for TA22 Celica
Current Time: Sat Oct 24 11:50:14 UTC 2026
Total time taken to generate the page: 0.0047450065612793 seconds
