Toymods » Tech & Conversions » 1jz throttle body upgrade?
1j180sx
goldcoast
June 2005
1jz throttle body upgrade? Fri, 26 August 2005 10:05 Go to next message
hey guys,anyone know of a good throttle body upgrade for a 1jz,is it possible to just cut the front half of it off to get rid of the traction control butterfly and accessories as im not using it and will the motor still run ok?
thanks for any advice
Manny
Re: 1jz throttle body upgrade? Fri, 26 August 2005 10:24 Go to previous messageGo to next message
TRC reliance is integrated into some factory 1JZGTE ECUs, so it will depend on what ECU or vintage 1JZGTE you are using - aftermarket ECUs will of course not give a rats wether the butterly is there or not.
There are also non-TRC equipped 1JZGTE throttle bodies you could use if you wanted to avoid the cut/shut option.
1j180sx
goldcoast
June 2005
Re: 1jz throttle body upgrade? Wed, 31 August 2005 11:55 Go to previous messageGo to next message
hey mate,thanks for your reply ,well appreciated
EvilJack
Sutho/Hills NSW
Re: 1jz throttle body upgrade? Wed, 31 August 2005 12:12 Go to previous messageGo to next message
i have a 1jz TRC throttle body with the butterfly removed if your interested
1j180sx
goldcoast
June 2005
Re: 1jz throttle body upgrade? Wed, 31 August 2005 12:18 Go to previous messageGo to next message
thanks but i think i ll just cut mine off and modify it,it
ll keep me amused
ChuckLandwehr
Re: 1jz throttle body upgrade? Thu, 01 September 2005 07:32 Go to previous messageGo to next message
According to "Zoom" an XF Falcon throttle body bolts up.
cheers Chuck.
Re: 1jz throttle body upgrade? Thu, 01 September 2005 09:20 Go to previous messageGo to next message
According to Mr Shin, an XF throttle doesn't QUITE bolt up - it's close, but no cigar. You'll need to weld up two of the bolt holes and re-tap them, then make sure you carefully port the inside of the manifold to match the throttle.
wilbo666
Re: 1jz throttle body upgrade? Thu, 01 September 2005 14:10 Go to previous messageGo to next message
Is the stock one really that big of a restriction?
Re: 1jz throttle body upgrade? Thu, 01 September 2005 14:33 Go to previous messageGo to next message
Personally I wouldn't bother changing it unless you were also changing the plenum...
Manny
Re: 1jz throttle body upgrade? Thu, 01 September 2005 22:55 Go to previous messageGo to next message
wilbo666 wrote on Fri, 02 September 2005 00:10
Not until you're making near on 400rwkw according to Japanese tuners - I guess that's why there aren't many Japanese bolton upgrades for plenum and throttle body.
wilbo666
Re: 1jz throttle body upgrade? Fri, 02 September 2005 04:50 Go to previous message
Yeah I couldn't imagine it being a decent restriction! I think it is pretty large as it is!
400rwkw is pretty serious power Smile
Previous Topic:3rz-fe turbo
Next Topic:Rolla adjustable strut tops ... Choose btw what brands
Current Time: Sat Nov 21 04:56:34 UTC 2026
Total time taken to generate the page: 0.0046360492706299 seconds
