Toymods » Tech & Conversions » Quad throttle throat sizing questions
September_Squall
Melbourne, Australia
March 2005
Quad throttle throat sizing questions Fri, 26 August 2005 14:43 Go to next message
I know in carburetted applications throat/choke sizes must be selected such that airflow velocity at low engine speeds is high enough and stable enough to promote good fuel atomisation, while not unnecessarily restricting top end airflow.
Given my difficulty in finding appropriate carbs for my motor I'm starting to look into quad throttles and fuel injection a la EFIhardware, injection perfection etc but it's a new science to me.
What are the important detirminants of best throat sizes for EFI applications? I presume the compromises are the same, ie. drivability v. max potential power?
(Not looking for a spoon feed really, just guidance for initial research... thanks)
Re: Quad throttle throat sizing questions Fri, 26 August 2005 14:46 Go to previous messageGo to next message
the vague idea is that you want a certain maximum air velocity in the throats.. iirc, it's something like 300ft/sec ????
i guess if anythig you'd want them the same area, or slightly bigger than the ports.. ideall with an X-degrees angle from th trupmet to the valve, to accelerate the air all the way....
or something like that Wink
also depends if you want a wide torque range, or a top end mini-powerband Wink
September_Squall
March 2005
Re: Quad throttle throat sizing questions Fri, 26 August 2005 14:51 Go to previous messageGo to next message
Cheers for the input. I think Ed cross-posted a relevant thread both here and on Performance Forums (btw. how downhill has PF gon now!)
Off to search I go.
takai
Re: Quad throttle throat sizing questions Sat, 27 August 2005 00:42 Go to previous message
Heh, PF hasnt really gone downhill, more just become very very odd, as is the way with many online communities.
The thread which Ed posted is a good one, and if you are interested in the physics behind it all i suggest you speak to Nero on PF and do a backorder of the previous 2 issues of Race magazine, they have a very very very good write up on the physics of porting, which logically extends through to your throttles.
As for the throttles, the size is mainly determined by, as Stew has said, the inlet air speed which is required at the engine RPM which you are tuning for. So for example in my car, the tuned RPM is 7500rpm, and i cant remember exactly the inlet air speed, but it roughly equals 43.5mm throttle chokes, and im running 44mm (bored ST20v).
Lots of maths involved in that one though.
Previous Topic:ae101 antenna removal
Next Topic:Welding / Bogging holes in engine bay
Current Time: Mon Oct 26 18:59:21 UTC 2026
Total time taken to generate the page: 0.0038690567016602 seconds
