Toymods » Tech & Conversions » 1JZ POWER STEERING QUESTION
cressida_1jz
On Probation
1JZ POWER STEERING QUESTION Sat, 27 August 2005 15:08 Go to next message
This is the 2nd p/s pump i have had.The origional JZA70 needed a rebuild so i got that done.It only lasted 4 months.That 1 stopped working completely.
I put another one from a JZZ30 Soarer today and it still makes a noise when turning the wheel.That pump was of a Soarer that was working fine before they blew the motor up a month ago.
Is it my bad luck or is it something else that i should be looking for.The Steering was fine when the 7M was still in it.Car has done 97000 KM.
Any ideas?????
[Updated on: Sat, 27 August 2005 15:24]
petespipes
logan river brisbane
July 2005
Re: 1JZ POWER STEERING QUESTION Sat, 27 August 2005 16:04 Go to previous messageGo to next message
I agree there seems to be some weird shit involved here.One of the info sources i am into is Jim Hopkins,a very well respected Toyota freak with a lifetime of experience.this particular gentleman is not keen on mods at all.Jim continually states that we are putting components together that are not designed to work together.There seems to be a lot of these pumps fail or become noisy with the conversion.Is it normal for p.s. pumps to fail like this? Cheers.Pete.
[Updated on: Sun, 28 August 2005 10:36]
squeak
south west sydney
Re: 1JZ POWER STEERING QUESTION Sun, 28 August 2005 06:40 Go to previous messageGo to next message
Are we sure that the pump is the problem as I have aslo changed to 1JZ power in a MX83 and the steering at low speed is shocking compared to the 7m powersteering, I only changed the pump with the motor change and left the original rack in place.Have never really followed up the problem but have heard alot of comments about it.still have the jzx81 rack, maybe I need to put this into the cardigan carrier.
squeak
YelloRolla
On your mum!
Re: 1JZ POWER STEERING QUESTION Sun, 28 August 2005 09:06 Go to previous messageGo to next message
hmmm. I somehow don't think that the pump(s) are the problem here.
Did you bleed the system out properly when you installed the new pump?
I have also heard that sometimes they won't bleed properly unless you restrict one of the lines.
Mine was as noisy as a bastard until I bled it out (I didn't drive the car more than 6 blocks before bleeding it).
cressida_1jz
On Probation
Re: 1JZ POWER STEERING QUESTION Sun, 28 August 2005 10:57 Go to previous messageGo to next message
The pump acually works great in low revs.Its just making a slight vibration and a noise when turning the wheel in low revs.
The old one didnt work until 2,500 revs and was making a noise since the pump got rebuilt.And didnt work at all before the rebuild.Il try and bleed it by restricting the return line at the resivoir.
Would u think the pump mite be starving for fluid?
Or the rack mite be rooted?
[Updated on: Sun, 28 August 2005 11:00]
1JZ.747
Osama's hideout
Re: 1JZ POWER STEERING QUESTION Mon, 29 August 2005 00:16 Go to previous messageGo to next message
havent had a problem in 5 years with mine.
YelloRolla
On your mum!
Re: 1JZ POWER STEERING QUESTION Mon, 29 August 2005 00:38 Go to previous messageGo to next message
cressida_1jz wrote on Sun, 28 August 2005 20:57
There may still be some air in the system.
Jack the front of the car up so that the wheels are just off the ground. Keep turning the car from lock to lock at least a dozen times, make sure that the fluid is full and then take the car for a drive and see if that helps.
Ribfeast
Newcastle, Australia
March 2005
Re: 1JZ POWER STEERING QUESTION Mon, 29 August 2005 04:34 Go to previous messageGo to next message
Is the speed-sensitive steering hooked up?
My 1JZ Cressida has very heavy steering too, with a reconditioned 1JZ pump, and a JZX81 rack.
barned01
Re: 1JZ POWER STEERING QUESTION Mon, 29 August 2005 07:36 Go to previous messageGo to next message
having never played with a power steering car, what is involved in doing a power steering fluid change? and getting it back to factory specs and levels (assume novice for power steering racks here).
do they also make some sort of rattling/grinding sound in genral as well.
i fear the power steering on the soarer (jzz30) might be heading down the same path as yours cressida_1jz Sad
cressida_1jz
On Probation
Re: 1JZ POWER STEERING QUESTION Mon, 29 August 2005 11:51 Go to previous message
Its alot better now.a slight noise.The P/S resivoir has a mesh filter in it.The p/s place recomended me to take the top of the resivoir anc give it a good clean.He thinks the pumps starving for fluid.Thank you very much for the help guys.
Previous Topic:Reversing control arms? need Help do or don't
Next Topic:Roll Cage Designs - AE86 / KE70 Specs
Current Time: Wed Nov 18 06:21:00 UTC 2026
Total time taken to generate the page: 0.0056982040405273 seconds
