Toymods » Tech & Conversions » Corona Brake upgrade? HELP.
Airbrushguy
June 2005
Corona Brake upgrade? HELP. Sat, 27 August 2005 17:14 Go to next message
OK this is the car
http://i9.photobucket.com/albums/a90/TurboCorona/2.jpg
As far as I can tell it has everything the same as MX73 cressy.
Front vented discs and rear solid discs,
What is there that will be a big upgrade for them that can be bloted on with out to much modifacations, preferably just a bolt on item of some sort.
Where can I buy it how much or contact details of someone who knows. Thanks.
Need it bad I got major brake fade tonight like never befor, I have new fluid I had presure there it just didnt grab, had to enter a hairpin with the handbrake.
Not a good fealing.
peeack
Re: Corona Brake upgrade? HELP. Sat, 27 August 2005 17:33 Go to previous messageGo to next message
If it's the same front breaks as an MX73, pm Cruzida and ask about his upgrade kit which allows z32 / r32 rotors and calipers for the fronts.
jackel
Re: Corona Brake upgrade? HELP. Sat, 27 August 2005 18:49 Go to previous messageGo to next message
i dunno if the front disc setup is the same as a st141 or rt142 if so, RA60 calipers are a direct bolt on and cheap upgrade
Johnny
Sydney, OZ
Re: Corona Brake upgrade? HELP. Sun, 28 August 2005 12:21 Go to previous messageGo to next message
Being of similar vintage, I'd think it'll be a safe bet this has the same brakes as an RA60... the Hilux 4-spot/Pug combo work well on the RA's, so do a search on this setup.
GTtwin
Newcastle, Australia
August 2005
Re: Corona Brake upgrade? HELP. Mon, 29 August 2005 05:34 Go to previous message
MX-73 Rear discs are ventilated, MX-73 callipers are slightly larger and the pads have more surface area. I'm in the process of doing this swap right now on my ST-141. These will bolt straight on to the Corona IRS Rear end.
Previous Topic:4A-GZE - all the differences, similarities, and specifications in AFM and MAP sensor types LISTED!!
Next Topic:gen1 3sge PCV valve question
Current Time: Sun Oct 25 16:09:59 UTC 2026
Total time taken to generate the page: 0.044837951660156 seconds
