Toymods » Tech & Conversions » Distributor / Cam angle Sensor Questions
vin91
Darwin
Distributor / Cam angle Sensor Questions Sun, 28 August 2005 05:16 Go to next message
Is there A Distributor That has A Cam Angle Sensor Fitted or Cam Angle Sensor to Fit the 2S Engine?
Is it Part of the Distributor or Fitted Seperatly?
Where is it Positioned?
berad
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 05:49 Go to previous messageGo to next message
crank angle sensor (cas) you mean?... they are 2 different things that do the same sought of thing, so i woudlnt think an engine would have both.
[Updated on: Sun, 28 August 2005 05:49]
vin91
Darwin
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 09:26 Go to previous messageGo to next message
No.
Cam Angle Sensor does The Same as a Crank angle Sensor but I Believe it Runs off the CamShaft.
[Updated on: Sun, 28 August 2005 09:27]
berad
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 09:49 Go to previous messageGo to next message
yes it can be done and has but whats your point...?
you could call a dizzy a cam angle sensor really as it sits on the end of the cam shaft but i dont see where your going with this..
vin91
Darwin
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 10:36 Go to previous messageGo to next message
The Point is that I want to do it but am Unsure as To How. I have tried to find Such Info But No Luck. If you can recomend some reading or Info on this It would be appreiciated.
berad
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 11:02 Go to previous messageGo to next message
so what you want to do is remove the dizzy and put a smaller cas in there as to be more accurate and less space / neater
i read a heap on this shit a while ago but it all seemed a bit dodgy to me.. like to dodgy to even bother doing it , from what it said it worked fine but it wasnt a real performance engine or anything ill have a quick look and see if i can drag it up
vin91
Darwin
Re: Distributor / Cam angle Sensor Questions Sun, 28 August 2005 20:40 Go to previous messageGo to next message
Sort Of, I want to Change over to Fuel Injection and while not necessary it would be nice to control Ignition. My engine is not really a Performance engine after all it will be my Daily Driver When Finished. Although Extra Power is always Good.
berad
Re: Distributor / Cam angle Sensor Questions Mon, 29 August 2005 04:38 Go to previous messageGo to next message
nothing wrong with dizzy if you just want it for efi.. theres a write up on leaving your dizzy on and convertin it over to msd coil packs... that would be a smarter idea
heres the link have a read...
http://www.4gcelica.net/v5/diy/coil.html
they just use the dizzy as the cas...
[Updated on: Mon, 29 August 2005 04:38]
vin91
Darwin
Re: Distributor / Cam angle Sensor Questions Mon, 29 August 2005 08:02 Go to previous messageGo to next message
OK Thanks for that Info, Would still be interested in My first Idea Just to Compare with this Method.
NickZ
Launceston
Re: Distributor / Cam angle Sensor Questions Mon, 29 August 2005 09:45 Go to previous messageGo to next message
I have done just what you are asking, My rolla has a 2T-GEU and ive adapted a 4AG 20 Valve CAS to the original dizzy to run a Microtech MTX8 with multicoil and sequential injection.
see my sig for the link to my car and youll see what ive done and a bref discription on how i did it.
vin91
Darwin
Re: Distributor / Cam angle Sensor Questions Mon, 29 August 2005 11:11 Go to previous message
Thanks Looks Exactly What I want, Pitty there are no Close Up's or Diagrams but I get What Your Explaining. Thankyou
Previous Topic:Intercooler Pump. No power??
Next Topic:5E-FTE turbo CT9, CT12, CT20, T2, GT17 or TD04
Current Time: Wed Nov 18 11:08:25 UTC 2026
Total time taken to generate the page: 0.0074560642242432 seconds
