Toymods » Tech & Conversions » ecu microtech
browns
June 2005
ecu microtech Sun, 28 August 2005 06:40 Go to next message
hey toymods members,
i am after some information. i need to know what type of ecu would best suit my situation. i have a 1975 toyota corolla ke35 and i am putting a 5k fuel injected engine into it but the engine doesnt come with an ecu. i would also like to know if anyone has a second hand one that they would sell or know where i could get one from.
thanks Browns.
berad
Re: ecu microtech Sun, 28 August 2005 06:43 Go to previous messageGo to next message
id be looking for a std one, or looking into megasquirt , very cheap and the addons and features that it comes with outdo alot of the 900-1100 ecu's on the market.. depending on your budget of course but if your not going to modify the arse out of it no need to go spending 2k on an ecu and fiting it and tuning it.
[Updated on: Sun, 28 August 2005 06:45]
Re: ecu microtech Sun, 28 August 2005 06:53 Go to previous messageGo to next message
browns wrote on Sun, 28 August 2005 16:40
thanks Browns.
i was running my 4K with 7KE injection gear, on a megasquirt, ans it was very good... motor was fairly modded, cams were 275/285, 435thou lift, so idle vacuum was not crash hot, but it idled much better than with carby, and was smooth everywhere..
i can even send you a startup map that you would be pretty close Razz
plus MS is much cheaper and simpler to set up than other ECU's
for sensors, use camira water temp and air temp sensors.... and heated O2 for closed loop on cruise is best...
which manifold are you using? 4KE or 7KE??
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: ecu microtech Sun, 28 August 2005 07:02 Go to previous message
LTX8 can be had 2nd hand for around 650ish. pretty good ecu's once tuned properly
Previous Topic:will 205/60/15's fit an AE92 ?
Next Topic:2 wrongs DO make a right
Current Time: Sun Nov 1 05:45:40 UTC 2026
Total time taken to generate the page: 0.0044291019439697 seconds
