Toymods » Tech & Conversions » sprinter audio problems
d-86
February 2005
icon4.gif  sprinter audio problems Sun, 28 August 2005 08:23 Go to next message
hey wondering if anyone can help me...
ok i was installing my AMP onto my HEAD UNIT in my sprinter then i accidently
did something to spark it then my head unit turned off. Well try turning the car off then on again, but my head unit doesnt seem to work anymore.
ok things i did...
- check fuse box in engine back = seems fine
- check fuse on the head unit = seems fine
- took the power out to reset everything = nothing happen
so im out of ideas....
so wondering if anyone can help out.
Do you reckon the head units F***ed?
[Updated on: Sun, 28 August 2005 08:24]
SW20R
Re: sprinter audio problems Sun, 28 August 2005 08:33 Go to previous messageGo to next message
hmmm should still be ok..
do a check and trace the whole power source, make sure your ground is good.
where abouts in sydney are you?
if your near by bring the headunit with loom and i can test it out for you
Julz01
Re: sprinter audio problems Sun, 28 August 2005 10:01 Go to previous messageGo to next message
Make sure you also check the fuse box that is under the dash on the right hand side of the drivers side of the car.
Dale_ta22
Forster NSW
Re: sprinter audio problems Sun, 28 August 2005 11:17 Go to previous messageGo to next message
Check ground, acc and +12v with a multimeter.
devolutio
Re: sprinter audio problems Sun, 28 August 2005 12:52 Go to previous messageGo to next message
i'd be checking for 12v at the headunit plug, contant and ignition... if you have those go to jb hifi and buy another unit - nad be more careful!
otherwise install it in something other than a sprinter, sometimes this works,
hope this helps!
fOOZ86
Re: sprinter audio problems Sun, 28 August 2005 16:54 Go to previous message
Yeah it sounds like you blew the fuse in the kick panel on the drivers side, it's a 7.5 or 10 amp fuse, easy fix.
on a side note .. I have found, a 10inch sub in a sprinter is .. well it can deliver pretty insane amounts of bass! too much for me, ha.
Grant.
Previous Topic:4agze into 85 GTS USDM Help please
Next Topic:ae82 and ae92 gearbox
Current Time: Wed Oct 28 17:48:02 UTC 2026
Total time taken to generate the page: 0.035186052322388 seconds
