Toymods » Tech & Conversions » Setting up sync and reference timing with wolf!
rx793
Perth, Western Australia
Setting up sync and reference timing with wolf! Sun, 28 August 2005 10:33 Go to next message
Any clues on how to do this, the tuner i spoke to reckoned it was absolutly bullshit to set up and hard as to get started.
Is this correct?
Any easy known angles to attack it?
Steve
Re: Setting up sync and reference timing with wolf! Sun, 28 August 2005 11:25 Go to previous messageGo to next message
The software definately isn't as good as many other ECU's a lot of the time, but if I can manage to get it working, probably anyone can. Well, almost Razz
sideshow
Re: Setting up sync and reference timing with wolf! Sun, 28 August 2005 13:30 Go to previous message
i dont do alot of wolfs so i think they suk ass
take it to an expert
i know on a nissan with an old stinger u had to move the crank sensor back 50 degrees
but the common thing with most aftermarket ecus
u set the crank to 60 degrees before top dead centre
then at that point the cylinder reference signal in the dizzy should line up or trigger
if u have a dizzy with leads after u set up the 60 degrees cyl reference u then turn crank to 20 degrees before top dead centre and make sure the rotor button lines up with no1 sparkplug lead
if u dont understand this take it to an expert or just keep spinin dizzy till it starts or till battery goes flat Smile
Previous Topic:How strong are my Internals?
Next Topic:RA60 sunroof help
Current Time: Thu Oct 29 06:29:42 UTC 2026
Total time taken to generate the page: 0.04957914352417 seconds
