Toymods » Tech & Conversions » J160 speedo cable
cultus
Kuala Lumpur, Malaysia
April 2005
J160 speedo cable Sun, 28 August 2005 11:14 Go to next message
Hi guys, I am in the process of the Gen3 1GGTE (auto ecu) + J160 into RA60 project.
The J160 has a speed sensor and my GA halfcut digi meter is using a cable.
My question is: Is there a speedo cable that I can use on the J160?
There are 3 pins on the speed sensor, anyway I can connect those to the meter so it replaces the speedo convertor thingy behind the meter?
Any help would be very much appreciated...
Re: J160 speedo cable Sun, 28 August 2005 13:06 Go to previous messageGo to next message
You should be able to remove the speed sensor and replace it with a cable drive from another Toyota box. Send a PM to Stenno, he did exactly that with his V160, I think he used a part from a Landcruiser or something? Anyway chances are you can do the same with your J160. Smile
It would help if you could remove the sensor and post pics for us.
cultus
April 2005
Re: J160 speedo cable Mon, 29 August 2005 13:49 Go to previous messageGo to next message
The convertor has 4 wires : earth, key on, signal and ???
While the speed sensor has a 3 pin socket, but without the socket I couldnt tell which one is what... I opened it up, there is just a disc on the inside attached to the gear and back of the black cover is just flat.
http://img247.imageshack.us/img247/1011/p82900946bm.th.jpg
http://img354.imageshack.us/img354/7488/p82900953nj.th.jpg
http://img354.imageshack.us/img354/6281/p82900924ah.th.jpg
Sorry for the burry pic. Thanks again Norbie
Re: J160 speedo cable Mon, 29 August 2005 22:52 Go to previous messageGo to next message
That looks the same as the W5x speedo drive. Try grabbing one out of an RA60 gearbox and see if it fits.
cultus
April 2005
Re: J160 speedo cable Fri, 02 September 2005 13:11 Go to previous messageGo to next message
Thanks Norbie, you are right : the 2 housings are the same. However, the J160 has 35 teeth, a bit more than the W57.
What I did was swap the gears, the diameters of the two shaft are the same but the J160s was shorter by about 1.5cm.
So I cut the W57 shaft (correct length of course), machined the tip to fit the J160s, MIG then machined the weld.
Thanks again.
Re: J160 speedo cable Sat, 03 September 2005 00:02 Go to previous message
You can probably just get a W5X speedo gear with 35 teeth Razz Good to hear you got it working though.
Previous Topic:3sgte blow off vavle removal?
Next Topic:lights
Current Time: Sat Oct 17 20:25:10 UTC 2026
Total time taken to generate the page: 0.0046150684356689 seconds
