Toymods » Tech & Conversions » TD04 on 4AGZE
ToyT18
Hobart
TD04 on 4AGZE Mon, 29 August 2005 10:21 Go to next message
Has anybody done a FWD turbo conversion on a GZE using a TD04 i know a guy who is having trouble with oil return line positions and feeding lines being the wrong way up when turbo exhaust inlet housing is facing upward, any info would be good as to what some people have done, or suggest other turbos to use that are a good fit.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: TD04 on 4AGZE Mon, 29 August 2005 10:29 Go to previous messageGo to next message
line positions can be solved by braided lines.. since you can flex them.
i'd be interested in what a TD04/05 is like on a 4age engine. whats the responce like, power etc
12AT_KE25
Toowoomba
July 2005
Re: TD04 on 4AGZE Mon, 29 August 2005 10:33 Go to previous messageGo to next message
Depends on which TD04 you're using. Mitsu VR-4 and Subie WRX MY98 on (excluding STI) should be right.
If you're planning on rebuilding the turbo it doesn't matter because you can orientate the bearing housing anyway you like.
Steve
ToyT18
Hobart
Re: TD04 on 4AGZE Mon, 29 August 2005 10:38 Go to previous messageGo to next message
its from a 98 WRX, yeah thats what i thought about the turbo centre, is it possible to move it around your self or is this for a turbo specialist, with braided lines would u really want the drain line at the bottom so it drains better u dont want it flowing upwards do u?
4agte
Toronto, Downtown
Re: TD04 on 4AGZE Mon, 29 August 2005 10:41 Go to previous messageGo to next message
holy shit no drain line uses gravity dosent it!!!
Simon-AE86
Banned user
Re: TD04 on 4AGZE Mon, 29 August 2005 10:44 Go to previous messageGo to next message
think about it.. you have oil under high pressure going in one end... whats going to come out of the other? not nothing thats for sure...
ToyT18
Hobart
Re: TD04 on 4AGZE Mon, 29 August 2005 10:47 Go to previous messageGo to next message
ok well i spose Embarassed well what the fuck then why is he caring about what position they are in.
4agte
Toronto, Downtown
Re: TD04 on 4AGZE Mon, 29 August 2005 10:48 Go to previous messageGo to next message
true good point
Simon-AE86
Banned user
Re: TD04 on 4AGZE Mon, 29 August 2005 10:52 Go to previous messageGo to next message
can we talk about the performance of one of these turbos on a 4age now pls Razz
ToyT18
Hobart
Re: TD04 on 4AGZE Mon, 29 August 2005 10:59 Go to previous messageGo to next message
So can u take the turbo apart to move the centre bearing housing around or does the shaft need to be realigned or anything else?
ToyT18
Hobart
Re: TD04 on 4AGZE Mon, 29 August 2005 11:02 Go to previous messageGo to next message
Also he says the wastegate actuator mounts would be on the wrong side and wants to know if he can turn the compressor housing aswell?
TE72_Turbo
Re: TD04 on 4AGZE Mon, 29 August 2005 12:43 Go to previous messageGo to next message
Yes, you can rotate both the exhaust & compressor housings to obtain the correct alignment for the oil drain. Rotating both housings the same amount will result in the wastegate actuator still lining up, but may mean that the compressor outlet is pointing at the motor or something stupid, in which case you might need to do some custom work to bolt the actuator in a different position.
Simon-AE86: Was that a serious answer, or are you taking the piss? I hope its the latter.
kingmick
Banned by his request
moved to tamworth
Re: TD04 on 4AGZE Mon, 29 August 2005 21:54 Go to previous messageGo to next message
Simon-AE86 wrote on Mon, 29 August 2005 20:44
to the young blokes out there!dont listen to the above its crap.its called a drain for a reason.simone you obviuosly no sweet FA about engines and turbos.pull your head in,could cost someone alot of money if they took your advice.
mick
TE72_Turbo
Re: TD04 on 4AGZE Mon, 29 August 2005 23:17 Go to previous messageGo to next message
Thankyou Kingmick! Smile This forum continues to slide downhill with bullshi+ "I reckon" answers to serious technical questions Mad If you don't know, or don't have first hand experience, don't regurgitate someone elses useless advice Cool
Simon-AE86
Banned user
Re: TD04 on 4AGZE Tue, 30 August 2005 08:00 Go to previous messageGo to next message
lol Rolling Eyes
Big T
Re: TD04 on 4AGZE Tue, 30 August 2005 10:28 Go to previous messageGo to next message
I understood that the drain from the turbo MUST be gravity fed downwards due to the turbo aerating the oil and making it "frothy" for want of a better word. High pressure won't do jack if the oil's already been aerated.
I've seen a car with a td04 gze setup. Had never been dynoed and was running the stock ecu. Response was immediate and had basically ZERO lag. Runs out of huff in the upper range but perfect for a quick streeter. He had also kept the TVIS operational.
Eddie.
kingmick
moved to tamworth
Re: TD04 on 4AGZE Tue, 30 August 2005 10:42 Go to previous messageGo to next message
yes must drain down!
mick
ToyT18
Hobart
Re: TD04 on 4AGZE Tue, 30 August 2005 12:45 Go to previous message
Thank you to all those people who corrected simonAE86, mate if u arent sure i dont want to know. Well yes i always thought to myself that it must point downwards for some reason as every turbo i have ever seen has done so, i also remember reading it in a magazine which i found today which mentioned about the turbo airating the oil.
Previous Topic:20V motor in a SX twim cam
Next Topic:Crown wheel and pinion matching?
Current Time: Mon Oct 19 13:46:35 UTC 2026
Total time taken to generate the page: 0.080224990844727 seconds
