Toymods » Tech & Conversions » Rolla adjustable strut tops ... Choose btw what brands
pluto55
Melb
August 2005
icon1.gif  Rolla adjustable strut tops ... Choose btw what brands Mon, 29 August 2005 12:23 Go to next message
ok..
The car KE55 currently running with RA65 struts v/disc and callipers. It pulls up good now Very Happy with good peddle feel too Surprised but the problem
Problem Embarassed
Im/it is 1&1/2 deg positive camber out on both sides (had this measured today)
What Brand of adjustable tops are there and which has better adj to get more Negative camber.. any ideas on price range too
Cheers Smile
September_Squall
Melbourne, Australia
March 2005
Re: Rolla adjustable strut tops ... Choose btw what brands Mon, 29 August 2005 14:03 Go to previous messageGo to next message
Check your clearance to the strut tower before you begin. If there's room to play with I prefer the Noltec solid tops as there's no polyeurethane bushing to shag out or for the springs to pound on.
If there's not enough room in the tower to offset the strut top for sufficient negative camber you could consider a control arm change. Most small Toyotas used the same inner lower bush and ball joint p/n. Maybe early Celica or later model RWD Corolla arms might be the go.
What kind of budgerigar are you?
[Updated on: Mon, 29 August 2005 14:04]
Re: Rolla adjustable strut tops ... Choose btw what brands Mon, 29 August 2005 14:16 Go to previous messageGo to next message
on a KE, 10mm = 1deg.
with my home made KE10 tops, i moved 20mm castor and camber = 2 deg of each.
for 1.5 pos, and you want 1neg at least, thats at least 25mm movement... you may be able to get that.. but maybe not with castor also.. depending on design..
Re: Rolla adjustable strut tops ... Choose btw what brands Mon, 29 August 2005 14:18 Go to previous messageGo to next message
oh, and check the spring clearance to the body.... thats the limit you can go before smaller springs.
maybe longer lower control arms...
pluto55
Melb
August 2005
Re: Rolla adjustable strut tops ... Choose btw what brands Tue, 30 August 2005 11:05 Go to previous messageGo to next message
yep ok.
1st'' the springs are not a problem if any thing they may go back up 10mm - 15mm to level the car out again. The boys at the Springworks will set that right after i solve the camber problem. im down an inch all round and they say that going lower will not fix anything. ie stroke of the strut too short & spring losing travel and the rears bump stop would be too close if i dump it all round + cost!
2nd'' LCA(arms) ive got a set of MX73 arms (these are only 10mm longer though) getting RA65 balljoints pressed in tomorrow to see the difference but i will need to get it measured again Confused , but before i do will need castor rods too..
<<What other LCA would Fit "anyone done this before with RA65's?">>
tried MX 61&62 but Track is out, wheel sits 20mm - 25mm lower then my standard setup, tyres directy under guards (which are rolled) with enough room to put your hand between the gap + camber is at big Neg, too big for a daily driver, It looked fat though!
3rd'' Struts, the struts are getting shortened revalved and Firmed up to suit. Evil or Very Mad , I can have them bent (as much as 3deg depending on -ride hight -size of wheels and tyres -alowance for tyre shake.) They asked me yesterday "would u be happy with 1/2 deg + camber(answer->NO)" <-- from this i estermate they can get 1 deg's doing this..
4th'' the guy doing my Struts mentioned "Noltec" an would prefer that i used these instead of Kmac.. any idea on Price? for Noltec? Maybe a place to get them from on the northern side of Melbourne.
Thanx for the info so far..
PS. anyone got Noltec in a KE55? what mod's if any i'll need to do?
Stefan
Hobart, Tas
Re: Rolla adjustable strut tops ... Choose btw what brands Tue, 30 August 2005 12:24 Go to previous messageGo to next message
T3 will make them for 170usd + 9usd shipping.
pluto55
Melb
August 2005
icon8.gif  Re: Rolla adjustable strut tops ... Choose btw what brands Thu, 01 September 2005 23:18 Go to previous messageGo to next message
ahhhh:blush: LCA still shitting me balljoints are not the same in the RA65 as they are a couple of mm smaller then MX73 ones. Looks can be decieving.. the LCA lengh is not as much as i'de hoped for prob 8mm..
Rolling Eyes probably dumb Question T3 .. is this the brand yes? what do they look like what are the specs? searched keep finding crap..
Shocked LCA have read that early Sigma fit and are 30mm longer.. Mad but i dont want some thing doge coz ill be needing a engeneering cirtificate, could hold off till eng conversion, but 2nd reasons Insurance.. What to do?
.. heard something about custom Bushes to fit where would these be made?
thanx boys
Stefan
Hobart, Tas
Re: Rolla adjustable strut tops ... Choose btw what brands Fri, 02 September 2005 00:49 Go to previous messageGo to next message
www.technotoytuning.com 170usd + 9usd shipping to Aus, made to order for rwd toys.
I will be taking some photos this weekend of the ones I bought.
Re: Rolla adjustable strut tops ... Choose btw what brands Fri, 02 September 2005 01:17 Go to previous messageGo to next message
Do you know if technotoy would custom make them to suit other cars?
Stefan
Hobart, Tas
Re: Rolla adjustable strut tops ... Choose btw what brands Fri, 02 September 2005 01:23 Go to previous messageGo to next message
Non-toys you mean? Quite possibly, as long as he has the bolt pattern measurements. I know he makes them for old nissan/datsuns and toyotas, and says if they don't have the model listed to give them bolt pattern measurements... so I don't see why not. Try emailing him.
September_Squall
March 2005
Re: Rolla adjustable strut tops ... Choose btw what brands Fri, 02 September 2005 02:53 Go to previous messageGo to next message
Small Toyotas around that age all share the same lower ball joint ~ 045. This includes Corolla, Corona, Celica, Carina, etc.
Large Toyotas around that age all share the same lower ball joint (some other one). This includes Cressida, Crown, MKII etc.
The large one and small one aren't interchangable.
The Sigma inner lower bush is different to the Toyota part, so modification is req'd to fit to the crossmember. If you use a Toyota arm with the same bush p/n the arm will fit with no modifications to the crossmember or bush.
Spend some time at Repco with their catalogues and you'll quickly draft up a short-list of things to try.
Ben Wilson
Re: Rolla adjustable strut tops ... Choose btw what brands Fri, 02 September 2005 03:48 Go to previous message
TurboRA28 wrote on Fri, 02 September 2005 11:17
He's really helpful (and a nice guy), it can't hurt to ask..
Previous Topic:1jz throttle body upgrade?
Next Topic:Whiteline adjustable swaybar
Current Time: Sat Nov 21 04:38:18 UTC 2026
Total time taken to generate the page: 0.0052120685577393 seconds
