Toymods » Tech & Conversions » Datsun 1600 struts into ke35???
ROTAROLA
April 2005
Datsun 1600 struts into ke35??? Mon, 29 August 2005 13:35 Go to next message
ive noticed that due to the popularity of putting sr20s into dato 1600s that huge brake upgrade kits are avaliable. they are around $1100 or sumfing.
but just wanting to know if they would be a relatively easy fit in to a ke35???
cheers Preston
[Updated on: Mon, 29 August 2005 13:52]
rollin_stock
February 2005
Re: Datsun 1600 struts into ke35??? Mon, 29 August 2005 14:00 Go to previous messageGo to next message
this works for the ke10. try using ke20 steering arms ontop of your ball joints, the spacing between the bolts on the bottom of the ke20 strut are the same as most datsuns, and do not use 1600 struts they are too long and the brakes are crap. Use 280zx then upgrade the calipers to 4spot toyota hilux late model ones for vented discs.
ROTAROLA
April 2005
Re: Datsun 1600 struts into ke35??? Mon, 29 August 2005 14:55 Go to previous messageGo to next message
cheers for the help.
ave a good 1.
Preston
Re: Datsun 1600 struts into ke35??? Mon, 29 August 2005 15:06 Go to previous messageGo to next message
just remember the earlier you go in KE series, the shorter the steering arms are = more direct steering, more ackerman angle, but more sloppines if your joints are not up to scratch Wink
triggboy
ipswich
Re: Datsun 1600 struts into ke35??? Tue, 30 August 2005 08:09 Go to previous messageGo to next message
i've got some s12 gazelle struts which basically came free with some rims i bought...anyway, i'm planning on using these on my ke10 as i was told they're the same as 280zx struts (they seem to have the same spring part numbers anyway)..does anyone know if this is right?
rollin_stock
February 2005
Re: Datsun 1600 struts into ke35??? Wed, 31 August 2005 07:28 Go to previous messageGo to next message
triggboy, im guessing they would be the same, you'll have to remove the spring seat because this will probably be too large to fit, i just went with a weld on coil over setup. you'll have to use ke20 ball joints (just push inplace of ke10 ones) and ke20 steerin arms.
triggboy
ipswich
Re: Datsun 1600 struts into ke35??? Wed, 31 August 2005 08:42 Go to previous message
ah cool...all good news. i was planning on using a coilover kit anyway.
thanks for your help Smile
Previous Topic:Can someone plz recommend a good Alarm/immobiliser for my ae86
Next Topic:4age idle up computer?
Current Time: Sat Nov 21 03:09:41 UTC 2026
Total time taken to generate the page: 0.0051279067993164 seconds
