Toymods » Tech & Conversions » SST ?
Mr_Grumpy
SST ? Tue, 30 August 2005 00:14 Go to next message
I'm unsure of this tool and apparently need it to remove the crankshaft pulley to beable to remove my timing belt.
I'm talking 4ac.
What can i use in replace of this?
Most older jap crankshaft pulleys just pops out, this one is blardy tight!
Re: SST ? Tue, 30 August 2005 00:41 Go to previous messageGo to next message
supercheap auto - crank pulley/harmonic balancer removal tool. $20-30.
STR8 2.8
Re: SST ? Tue, 30 August 2005 00:54 Go to previous messageGo to next message
btw there are many different sst's (special service tool) for different applications.
Re: SST ? Tue, 30 August 2005 14:22 Go to previous messageGo to next message
there are also many different WST's for many jobs....
towe_001
Somewhere on a dirt bowl ...
Re: SST ? Tue, 30 August 2005 14:27 Go to previous messageGo to next message
The SST you'll be after is SST09213-31021 but you'll be better off doind like what The Witzl said
towe_001
Re: SST ? Tue, 30 August 2005 14:33 Go to previous messageGo to next message
THE WITZL wrote on Wed, 31 August 2005 00:22
Yes just like 10gauge fencing wire Wink
Toobs
Re: SST ? Wed, 31 August 2005 03:05 Go to previous messageGo to next message
http://www.rollamods.com/witzl/AE71%20conversion/SST.jpg
Mr_Grumpy
Re: SST ? Wed, 31 August 2005 10:07 Go to previous messageGo to next message
Tried the supercheap auto one but the pitch of the bolt thread was different so it wouldn't screw into the crank.
Thanks for the advice guys, I'll figure something out. Some fencing wire around the pulley and a longer bolt with some thick washer should do the trick. Wink
btw toobs, thanks for the pic. I was just wondering with the bracket covering the crank bolt thread, how are you suppose to push the pulley out? Do you use a pry bar in between the bracket? or do u just use long bolts and screw them in until the pulley pops out??
thanks guys, good help and response here.
cheers! Very Happy
Re: SST ? Wed, 31 August 2005 11:42 Go to previous messageGo to next message
i think you have a few things confused....
# Supercheap Auto Crank Pulley Remover
- you leave the crank pulley bolt in, but undone. using two of the supplied bolts, bolt the big stary thing to the pulley and then bolt in the big long black centre bolt so that it starts pushing tight against the crank pulley bolt. The pulley will now start lifting off.
# Using WST-011 pictured by Toobs:
- again the crank pulley bolt is in the crank, but undone. Tightening up the two bolts either side starts to pull off the pulley as the metal plate is squeezed against the crank pulley bolt.
tricky
July 2005
Re: SST ? Wed, 31 August 2005 12:13 Go to previous messageGo to next message
Nice one Toobs, that's how I woulda done it!! No fancy tools for me if 'agricultural' techniques will do it Cool
Re: SST ? Wed, 31 August 2005 12:46 Go to previous messageGo to next message
umm... that's actually my WST-011 that toobs has pictured Razz
6000% Witzl-spec.
Mr_Grumpy
Re: SST ? Wed, 31 August 2005 13:43 Go to previous messageGo to next message
thanks alot guys, yeah i was going to use that technque lol, i guess my explaination wasn't so clear as i was blabbing on.
tricky
July 2005
Re: SST ? Wed, 31 August 2005 14:49 Go to previous messageGo to next message
Ahhh, my apology Witzl.. U need 2 patent yo shit to avoid the pinchage by Toobs, hence leading to the misunderstanding of teh Tricky!! I even remember reading the WST post and getting a few laughs Smile .
Toobs
Re: SST ? Wed, 31 August 2005 22:57 Go to previous message
Yep that was Witzl's one... I was the one who told him he was a donghead and that he should have used the crank pulley remover that we already had!
Previous Topic:Converting from FWD to RWD.
Next Topic:toyota 4ac workshop manual
Current Time: Sat Oct 17 12:01:20 UTC 2026
Total time taken to generate the page: 0.08404803276062 seconds
