Toymods » Tech & Conversions » urgent help needed on 18RG elec dizzy convo
Mr DOHC
urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 06:31 Go to next message
i am currently hooking up elec ignition to my 18RG
need a few q's andwered
where do these plugs all go, {from left to right if possible}
http://img399.imageshack.us/img399/8817/img80419mn.jpg
far left is to coil obviously
and from left is single wire only
middle is 2 wire, and one of them goes to the black ended green plug
and where do the 2 green plugs go
should i run my ballast resistor thats already on there
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 07:05 Go to previous messageGo to next message
you dont use a ballast resistor.
You need a coil designed for electronic ignition (with ingitor), otherwise you'll burn out the coil.
the two ring terminalled connections go to the coil. The terminal with two wires is the positive, and the single wire black is the negative.
The two green plugs are easy Smile
im pretty such each of those plugs has only one wire, correct?
If so... then the left hand green plug (which goes to teh coil positive) is IGNITION...
and the right hand green plug (which goes directly to ignitor and nothing else is TACHO OUTPUT.
With regular points ignition the tacho wire is connected to teh negative of the coil... you can still do this, but its more accurate using the TACHO output of the ignitor.
Mr DOHC
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 07:16 Go to previous messageGo to next message
got it going, b4 your post anyway, just slid back the sheath on the wires, hmmmm, black wire, negative obvoiusly, and the other must go to the positive
i got the standard replacement coil for a RT142, brand new {$25 too Wink }
so should i remove the stock corona ballast resistor, if i dont what will happen, will satan come get me, hope so, i need to have words with him Mad
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 08:48 Go to previous messageGo to next message
no - you'll just get crappier spark.
ra40coupe
May 2005
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 09:00 Go to previous messageGo to next message
btw what ingiter is that off?
i got the same one and i never knew what it was off. i heard a SV21 camry
meh??
Mr DOHC
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 09:47 Go to previous messageGo to next message
talk to witzl, he got it for me
how do i by pass the resistor, do i just unplug it,
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 14:21 Go to previous messageGo to next message
you need a big fuckoff prybar Razz
or what you said. And then bin it.
M.W.P.
Rocky Mountains, Canada
Re: urgent help needed on 18RG elec dizzy convo Tue, 30 August 2005 15:53 Go to previous messageGo to next message
I could probably give you info on how to use a Bosch ignitor readily availiable from SuperCheap if you like.
I use one along with a coil off a Tercel (small transformer type) on my 21R.
Works very well.
Mr DOHC
Re: urgent help needed on 18RG elec dizzy convo Wed, 31 August 2005 02:42 Go to previous messageGo to next message
do i then have to hook the 2 wires together for it to work
Re: urgent help needed on 18RG elec dizzy convo Wed, 31 August 2005 04:51 Go to previous message
well the ballast resistor in the standard setup has ingition going to one side, and the other to the coil positive, IIRC
Basically take off the ignition side and hook that up to where i said IGN wire is above Smile
Previous Topic:5s-fe to turbo
Next Topic:Checking compression and leak-down on ST185
Current Time: Sat Nov 21 02:41:22 UTC 2026
Total time taken to generate the page: 0.0062601566314697 seconds
