Toymods » Tech & Conversions » Installing Boost Controller into Soarer
Remedy
Southern Sydney
Installing Boost Controller into Soarer Thu, 26 December 2002 22:46 Go to next message
Hey Guys,
I received my HKS EVC 3 Boost controller fresh (well slightly used) from Malaysia on Monday and am planing on installing it tomorrow.
I've looked up the PDF manuals from the HKSUSA.com website and it all looks fairly straight forward but they only have documentation for single turbo applications.
What is the easiest way to install the actuator. Do I just link the wastegate lines together with a T piece to the actuator?
Any of those who have installed a boost controller (manual or electronic) previously, what size tubing is needed?
Any other pointers would be greatly appreciated.
jza70-mel
Perth WA
Re: Installing Boost Controller into Soarer Sat, 28 December 2002 09:51 Go to previous messageGo to next message
The T piece is the go, with same diameter piping as the HKS piping. (at least that is what is running on my Apexi AVC-R)
The Apexi USA site may have some documentation on the 1JZ engines
[Updated on: Sat, 28 December 2002 09:52]
Bounty
_Sydney _
Re: Installing Boost Controller into Soarer Mon, 30 December 2002 10:59 Go to previous messageGo to next message
Remedy I went through the same thing with hookin up my boost controller, you gotta T up both turbo acurator lines, go to ur local repco or whoever get some fuel hose line doesnt need to be efi, same thickness as whats already connected to the accurators i got some left over if u need to know what thickness etc. 2 T connectors and one straight conector, and abt a dozen small hoseclamps. pretty easy to do but ull have a bitch of a time getting to the rear accurator line and connecting that but once u got that its easy connect the two pressure ends together with a t piece and the same for the accurator side t piece and then between those two put ur boost controller solanoid or the connector fitting ur suplied with that goes to the unit make sure its all clamped up and hey presto couple hrs later and a few $%$#$^ that sux getting ur hands behind that back turbo shell be sweet Smile good luck.
Remedy
Southern Sydney
Re: Installing Boost Controller into Soarer Mon, 30 December 2002 12:49 Go to previous messageGo to next message
so what did you have to remove to do this.
Did you take the heat sheild off etc.
I hope I don't have to do that cause that means pulling off all the induction piping aswell.....
If thats the case I think what I may end up doing is installing the electronic side of it (ie controller into cabin, loom through firewall) which I'm okay at and leave the mechanical side of things to the local auto electrician which should hopefully only cost an hours labour or so.
Bounty
_Sydney _
Re: Installing Boost Controller into Soarer Tue, 31 December 2002 06:29 Go to previous message
Nah you dont have to take of heat shield and all that stuff, if you really want a hand let me know I can help ya out do the electrical side of it and I can show ya my setup and show you what has to be done.
Previous Topic:HELP! Electrical problems :s
Next Topic:3" high flow catalytic converter - Where to buy???
Current Time: Sat Oct 24 09:09:52 UTC 2026
Total time taken to generate the page: 0.0047359466552734 seconds
