Toymods » Tech & Conversions » W series gearboxes
customSA63
Adeliade
February 2005
    NA
W series gearboxes Tue, 30 August 2005 09:45 Go to next message
hey all i have a w55 in my sa63 celica and i got another one out of an identical car but the gear box feels so much better and closer range as well as the gear knob been shorter??
the question is i was wondering where on the gear box it states its a w55 or w58 becasue there is no F***ing way this is the same box as my car.
EG it feels like shifting in a WRX its a very wierd box and would like some input on where the gearboxes name is.
matt
Smile
wilbo666
Re: W series gearboxes Tue, 30 August 2005 11:18 Go to previous message
It won't say anywhere on the box that it is a W55.
W55, W57, W58 (without the steel sandwich plate) are (as far as I know Smile) not possible to tell apart by visual inspection!
The best way is to count input:output revolutions to calculate the ratios.
There really isn't that much difference in the ratios in my opinion...perhaps it just has much better shifter bushes in it (this does make a large difference to the shift feel)?
Also another thing you could check is that if it appears that the rear extension housing has been removed (off your new box) in the past that may imply that the gearbox is not from a SA63, as SA63 celicas are the only one that I am aware of that have that shifter position. It would stand to reason then if a W57 or W58 has been swapped in that the swapee would/should have swapped the old SA63 postion onto it, which requires removing the rear extension housing off the gearbox. Smile
[Updated on: Tue, 30 August 2005 11:26]
Previous Topic:Crown wheel and pinion matching?
Next Topic:S.C AW11 over fueling, help please
Current Time: Sun Oct 18 03:17:33 UTC 2026
Total time taken to generate the page: 0.0044379234313965 seconds
