Toymods » Tech & Conversions » Engine warning light? What does this mean
SW20R
Engine warning light? What does this mean Tue, 30 August 2005 12:26 Go to next message
http://img296.imageshack.us/img296/4795/dsc002544vj.jpg
http://img296.imageshack.us/img296/8097/dsc002535se.jpg
This icon appeared just after washing my car. engine temp on the dash didnt go over half way and the oil cap is fine.
My car is a MR2 Turbo, 3SGTE GEN 2.
I can hear some bubbling noise comming from the radiator cap I believed my radiator cap is busted as its not holding pressure? what else could this mean?
thanks!
Dale_ta22
Forster NSW
Re: Engine warning light? What does this mean Tue, 30 August 2005 12:30 Go to previous messageGo to next message
You'd need to check the ECU for the error code.
I think there's two connectors you bridge and then the light will flash a certain amount of codes which corresponds to a certain error.
You'll need to find a reference of the error codes and what pins to bridge for your car/engine, though.
and if in doubt it would pay to replace the radiator cap just to be sure!
[Updated on: Tue, 30 August 2005 12:31]
SW20R
Re: Engine warning light? What does this mean Tue, 30 August 2005 12:53 Go to previous messageGo to next message
I got 2 codes,
24 Intake air temp sensor
http://www.mr2-tech.com/bgb/mechanical/volume1/efi_system/Manual_0345_0001.jpg
34 Turbocharging pressure singal
http://www.mr2-tech.com/bgb/mechanical/volume1/efi_system/Manual_0346_0001.jpg
I dont have my turbo VSV as im runnig an aftermarket boost controller
I think its my ecu.. I've got a video of the diagnostic codes if anybody wants to host it.
It gave me code 21,22 at first then it repeated 24, 34
[Updated on: Tue, 30 August 2005 13:15]
Re: Engine warning light? What does this mean Tue, 30 August 2005 13:10 Go to previous messageGo to next message
how are you getting codes if you have an aftermarket ECU?
SW20R
Re: Engine warning light? What does this mean Tue, 30 August 2005 13:16 Go to previous messageGo to next message
sorry i meant boost controller woops!
Re: Engine warning light? What does this mean Tue, 30 August 2005 13:21 Go to previous messageGo to next message
could it just be the ECU boost cut kicking in?
SW20R
Re: Engine warning light? What does this mean Tue, 30 August 2005 13:31 Go to previous messageGo to next message
Could be it still drove fine but I was just scared as it didn't look like a check light but an overheating symbol. The engine has a fan lit up in red. isn't the check light normally orange only?
i've disabled the turbo pressure sensor plugged it off so it can go over 7Psi without fuel cutting.
VeeP
May 2005
Re: Engine warning light? What does this mean Tue, 30 August 2005 14:11 Go to previous messageGo to next message
happens in my soarer every now and again - i find that occasionally water will make its way into the engine bay, and will wet a connector giving a computer a bogus signal since now there is a bridged connection where its not meant to be. Just to be sure thats not ur prob, pop ur bonnet - err boot - and make sure all the connectors are dry (inside and out) and just check that no components have actually been soaked. .
SW20R
Re: Engine warning light? What does this mean Tue, 30 August 2005 14:17 Go to previous message
ah ok cheers!
I did just come from a car wash. and noticed it kicked in 20seconds after
Previous Topic:What brakes for a KE30
Next Topic:ae82 brakes (please confirm something)
Current Time: Sat Nov 21 05:12:15 UTC 2026
Total time taken to generate the page: 0.0052638053894043 seconds
