Toymods » Tech & Conversions » Stereo problem
old_mr2
Stereo problem Wed, 31 August 2005 08:09 Go to next message
Hello
The other day i had to disconnect my negative battery terminal to access a bolt. I have reconnected but the problem is my stereo has now died. It worked for 20 minutes after reconnecting the battery neg terminal but now has died completely
I have checked all fuses and all apear to be fine.
Can anybody help me sort this out cause i need music!!!
As yet, i have not tested stereo connections with a multimeter, i thought some of the stereo guru's might know what I have done Shocked
Re: Stereo problem Wed, 31 August 2005 08:11 Go to previous messageGo to next message
You checked the fuse on the back of the deck?
Also check the earth.
old_mr2
Re: Stereo problem Wed, 31 August 2005 08:22 Go to previous messageGo to next message
I have checked the 15A that goes to the 12V constant and its fine
By earth do you mean ground wire to the head unit?
GTtwin
Newcastle, Australia
August 2005
Re: Stereo problem Wed, 31 August 2005 08:25 Go to previous messageGo to next message
What sort of Stereo. Does it need a Security Code.
Factory Lancer Decks (Clarion), for example, will operate for a few minuits and then shut down without a code.
pomey
May 2005
Re: Stereo problem Wed, 31 August 2005 08:30 Go to previous messageGo to next message
I'm no stereo guru as such, although i've installed a fair few for friends and myself. I am, however, an electrician therefore have fault finding knowledge.
In my experience first check all fuses, then supply, then ALL connections. Most commonly it's just a loose connection, in the most awkward spot of course, that's the culprit. If all else fails, get a $15 multi meter from dicksmiths.
Hope this helps and hope u get it goin!
Cheers, Pomey!
old_mr2
Re: Stereo problem Wed, 31 August 2005 10:22 Go to previous message
Thanks guys the fault has been rectified. It was a ground wire problem.
Previous Topic:simple question on conversion rules
Next Topic:18RGEU
Current Time: Sat Nov 21 02:41:22 UTC 2026
Total time taken to generate the page: 0.0050499439239502 seconds
