Toymods » Tech & Conversions » got me stuffed!!! 1ggte engine mounts plz help
CrAiGzEE
south of the big smoke
got me stuffed!!! 1ggte engine mounts plz help Fri, 27 December 2002 03:07 Go to next message
ok i have fully read all the conversion tutorials about 100 times, can some one explain on how to get the 18r mounts to fit up to the 1g?
i know you have to use the most front mounting wholes but the dip stick appears to be in the way on one side and what looks like to be a oil return from the turbos on the other.
i like ddeans idea of mounting the mounts upside down so i wont need a spacer etc, but the mounts dont appear to line up
here are some pics.
also which mount do i use on each side?
feel free to draw all over them to explain it
you can email me edited copies
Oz_Craig@bigpond.com
1
http://www.users.bigpond.com/digger_aus/savedfiles/1.jpg
2
http://www.users.bigpond.com/digger_aus/savedfiles/2.jpg
3
http://www.users.bigpond.com/digger_aus/savedfiles/3.jpg
4
http://www.users.bigpond.com/digger_aus/savedfiles/4.jpg
5
http://www.users.bigpond.com/digger_aus/savedfiles/5.jpg
6
http://www.users.bigpond.com/digger_aus/savedfiles/6.jpg
all help would be greatly appreciated
CrAiGzEE
Re: got me stuffed!!! 1ggte engine mounts plz help Fri, 27 December 2002 03:33 Go to previous messageGo to next message
btw if anyone is willing to come and help put the engine in that would be great!
i will pay ya!
knackers
berala sydney
Re: got me stuffed!!! 1ggte engine mounts plz help Fri, 27 December 2002 04:05 Go to previous messageGo to next message
oz_craig
mate i think you will have to get some engine mounts made as far as i now the 18r's will not fit >Iam in the middle of a 1g transplant at the moment and man what a pain .Got to much for me so am sending to the shop.They are going to fit motor fab engine mounts gearbox mount and fab the sump .Will let you no how it goes.Got sume bits and peicers here dont no if any good but when i am finished your welcome to have a look to see if anything is of value.May be able to ask at the shop how much it is to make you a set of mounts when i go to drop the car of in the first or second week in jan.Hope any of this info may help. Smile
cya for now les
CrAiGzEE
Re: got me stuffed!!! 1ggte engine mounts plz help Fri, 27 December 2002 04:30 Go to previous messageGo to next message
mate how much is all that setting you back?
a price on the mounts both gearbox and engine would be great
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: got me stuffed!!! 1ggte engine mounts plz help Fri, 27 December 2002 13:42 Go to previous messageGo to next message
From what I remember, Phill (TRACTION_ISSUES) used a spacer with the 18R mounts. Well, his previous engine was an 18R AFAIK...
Re: got me stuffed!!! 1ggte engine mounts plz help Sat, 28 December 2002 05:27 Go to previous messageGo to next message
from what I remember, fabricated engine mounts was the way to go with that conversion. it'll probably cost you a pretty penny, unless you can contact knacker's mechanic, and get him to make you up some mounts at the same time. that way it would cost you almost nothing, as all the measurements would already have been made.
CrAiGzEE
Re: got me stuffed!!! 1ggte engine mounts plz help Sat, 28 December 2002 05:35 Go to previous messageGo to next message
knackers have you got a number i can contact you on?
RA28
Re: got me stuffed!!! 1ggte engine mounts plz help Sat, 28 December 2002 10:56 Go to previous messageGo to next message
Dude, you need the mounts off of a 1gge, they have fabricated-type mounts instead of the cast ones that came with the 1GGTE. the 1GGE mounts look like the 18R mounts, but with 4 holes to bolt them to the engine. these fit with a little drilling...then bolt (with a spacer or upside down or whatever) then onto the engine cross member.
I don't think you can get the 18R mounts to fit without some heavy mods...
Tim.
ddeane
PNG
Re: got me stuffed!!! 1ggte engine mounts plz help Sun, 29 December 2002 08:30 Go to previous messageGo to next message
Craig
I think that you are making this harder than what it is. Just give me a ring and I will talk you through it. It really is quite simple with the bits that you have!
Craig
ddeane
PNG
Re: got me stuffed!!! 1ggte engine mounts plz help Sun, 29 December 2002 08:35 Go to previous messageGo to next message
Craig
While I think of it. Wot type of mounts did you motor come with. If the engine was out of a supra it will have iron pressed brackets. However if it is from a sourer it will have the cast alloy mounts. If this is the case you do have some problems. It might pay to get onto Dylo - try the ACT thread ans he had some of the supra ones fabricated. Have a look at the conversion article as this will show you what they look like. Otherwise start checking out the importers.
Craig
Craig
Bugman
Re: got me stuffed!!! 1ggte engine mounts plz help Sun, 29 December 2002 09:18 Go to previous message
yeah craig has the rear mounted cast alloys.
his was out of a 1988 supra, my one was also a 1988 supra and it had rear mounted steal fabricated mounts, which only need slight modification to mount in the forward position, but becuse I'm a retard I slightly stuffed it and had to modify both 'feet' to the mounts.
Previous Topic:4AGE 20v...'Blacktop'
Next Topic:Always double check
Current Time: Thu Nov 19 11:35:21 UTC 2026
Total time taken to generate the page: 0.019643068313599 seconds
